This is getting embarrassing and frustrating.
This is a normal for Plex Android every time thereās a time change. Right around 2 a.m. it should start working, depending on your time zone. But Iām not up at that time, I just wake up the next morning and it works again.
Considering this as ānormalā is brutal. Fix this already.
I was hoping not to re-subscribe to my hd homerun dvr service in a couple weeks. Unfortunately, plex and live tv/dvr do not work together. Iāve tried it on and off for a couple of years and was hoping it would be there by now. Itās definitely not. HD Homerun has worked well for me for 4 years.
I forgot I made a post last year lol.
Thereās been a new Beta updated which supersedes the version in this thread. However, on a Shield Pro, playing any Live TV for around 20 seconds (maybe less) crashes the whole app. Happens on any channel. @sixones something youāre aware of?
@sixones @SamFromPlex
App version: 8.15.0.23605 (821412696)
Same here. The BETA just released completely crashes Plex out to the Amazon Fire Stick main menu when playing Live TV/DVR.
Fire Stick 4k crash 8.15.0.23605.txt (269.2 KB)
A new beta will be deployed shortly that includes a fix for the crash when playing Live TV.
Would you be able to share your logs? Will pass it on.
Steps for gathering the logs are available here; Android, Android TV, Fire TV Logs | Plex Support
Do we know when this will be released? Tempted to roll back so I can watch TV this evening but wonāt if a newer version is imminent
Anyone else unable to play some 4k content with the beta release? Was able to on the previous versions. Now FireTV times out with a error āAn error occurred while attempting to play this video. Please check your connection and try again.ā.
I am not seeing any network traffic indicating it is even attempting to start the direct stream. Tried a firetv via wifi and hardwired. Same result with both.
Settings are all at play original file. Tried a few 4k copies I know have worked in the past.
App 8.15.0.23515 (d988edae)
Server 1.22.0.4163
Same issue as OP, my recorded TV has the same issue of looping if I was trying to watch Live TV while it was being recorded. I see there was a beta fix for it but itās now superseded and not working again.
Hi Sixones,
I started a new thread for the Fire Stick dropping back to guide when changing channels.
Logs are attached. Let me know if you need anything else.
Thanks.
The new beta was released last night, apologies for the delay.
Could you provide some logs from the client after replicating the issue? https://support.plex.tv/articles/201573117-android-android-tv-fire-tv-logs/
Would you be able to provide the client logs after replicating the issue in the latest beta?
No problem. Thanks for updating. The issue with changing the audio channel on Live TV and DVR is still present where it crashes the whole client. I believe Logs have been given for this already.
Just realised the āwatch from beginningā issue is still present on the latest beta where it will just keep looping.
Yeah, which will make me pay for another tear of hd homerun dvr service.
- Player: improve Live TV playback.
Thereās some sort of improvement to Live TV playback in the latest beta, anyone try it out? I can test it out in a little bit here.
Plex for Android 8.15.0.23698-beta Available on Google Play, beta access can now be joined (or removed) directly from the Google Play store listing. FIXES: Player: crash could occur when playing an item from the postplay. Preplay: cast list could contain duplicate items. Player: improve Live TV playback. Deeplinks: app could fail to open if attempting to play media while in the background. BETA: Player: prevent potential crash sending timeline events. DOWNLOAD APK (Plex Pass required): ā¦
