hey @michabbb2 - you posted a link to the forum. Were you trying to link to a specific post?
fantastic news - thanks!
…any updates on the other topics in this thread, namely SD/HD channel and recording problems and the missing EPG’s for certain countries still?
sorry, sorry!
Hi - you already have @cire12 talking to you directly on that other post so no need to duplicate it here
@cire12 please help with the SD non HD EPG issue. Even just to say you’re aware of it and working on something, but we haven’t heard a thing.
UPDATE: Split Movies (Freeview UK)
Good news everybody, we’ve injected the logic to reconstitute split movies into a single airing. Per @sa2000’s post on the 16th this will target split movies on the channels that the community has identified as problematic
Excellent
Just set up a dozen movies to test out recording these split movies - All of them that I checked had the split joined
I normally use MCEBuddy for commercial skip and convert to MP4 HEVC
Will see how this shapes up and try your commercial skipper when I know my process works reliably
I have made the appropriate team aware of the issue.
great. Can you tell us who the appropriate team is and then we don’t need to bother you with it any more?
cheers.
Will there ever be a ITVHD logo? Postcode:le2
I’m just on the other side of the A5 (Postcode CV23) - so not too far from you - and have the ITV HD logo here.
I appreciate it doesn’t help you but I wonder why there is a regional issue with logos?
I take it this has been an issue for a while now and that you’ve tried manually refreshing the guide data?
My cached copy of the logo is at C:\Users\Steve\AppData\Local\Plex Media Server\Cache\PhotoTranscoder\de\de49463b77d15708d0b65aacd2c57f3a330228e0.png.
There are a bunch of directories under PhotoTranscoder where Plex caches the logos for the channels as well as the artwork for movies and shows.
I’m wondering if you have a corrupt version of the file - if so it might be worth deleting it? If not I would check the log files to see if you can see the reason why it might not be downloading.
Is anyone else seeing lots of Unknown Airings on Freeview here in the UK from 06:00 on Sunday 28th throughout all of next week? For example:
I’ve tried refreshing the guide data and restarting Plex for Windows but with no avail. I’ve not tried restarting the server yet as it is currently recording.
Postcode: CV23
I have noticed a lot of unknown airing appearing on the left edge of the guide, when the programme start time is earlier than the current grid view on display. Then when you scroll back in time unknown airing is replaced by the programme details.
Thank you very much for your reply. I’ll look into your suggestions. I have noticed when others post screenshots they are also missing ITV logo. I was missing BBC4 until recently too, but that just populate by itself.
Hi both - I have reported this elsewhere (not that I have any confidence something will be done). If you scroll left, those unknown airings will show the real airing. There is something weird going on with partially-shown and just-started airings in the guide.
Server Version#: 1.22.0.4163 Player Version#: 1.29.1.1974-a65b3ef3 OK, so this is unusual. I see “Unknown Airings”, but only when the episode is partially shown in the EPG or starts at the first shown time in the EPG: Unknown (time set to 18:30): [Screenshot 2021-03-21 at 11.43.36] OK, time set to 18:00: [Screenshot 2021-03-21 at 11.44.30]
@cire12 I deleted DVR, deleted the cache folder, but no luck. The ITVHD logo is still missing for LE2
So when you updated the database and refreshed it then recorded in HD? If so, seems like a very simple fix as it only needs to filter the channel tagged as HD rather than the resolution of the programme?
I don’t know if it would affect the recording in SD or HD, as I normally specifically select the relevant SD/HD channel depending on I want HD or not, but I would think that if it affects the filtering it would also affect the recording.
Cheers Rich - It seems to be the same problem I am seeing as well.
Ah yes - I have now tried more of the pre-defined times of day and not just “Morning” (06:00) and see the same happening as well. Bizarrely some programs that start dead on the hour also exhibit the problem - but not all.
For example:
The “Unknown Airing” on ITV3 at 06:00. in my original above screenshot should be “On the Buses” S3 E4 but only displays that when you scroll to 05:30.
However, “Breakfast” on BBC1 at 06:00 shows correctly.
Very strange. I wonder if this is be related to the “Unknown Airings” issue on the HD channels when you choose HD only?
It might be a Plex / Cloudflare server side issue with your region ![]()
You could try looking in the main log file for de49463b77d15708d0b65aacd2c57f3a330228e0.png.
As you are in a different region to me your ITV HD logo may have a different file name but you could look for channel 103, ITV1 HD or even .png.
My main log file is located at:
C:\Users\Steve\AppData\Local\Plex Media Server\Logs\Plex Media Server.log
For example I have entries such as the following in mine:
Mar 27, 2021 04:44:14.905 [4468] DEBUG - EPG[cloud]: Matched channel 103 (ITV1 HD ) with grabber channel, adding.
Mar 27, 2021 14:39:45.715 [4220] DEBUG - Request: [192.168.5.4:38872 (WAN)] GET /photo/:/transcode?width=240&height=240&url=https%3A%2F%2Fprovider-static.plex.tv%2F1%2Fepg%2Fchannels%2Flogos%2Fgracenote%2F16617a15d293f6aeb593ae58c58a7d4c.png&minSize=1&upscale=1 (28 live) GZIP
Mar 27, 2021 14:39:45.727 [4220] DEBUG - [Transcode] Photo transcoder: Request for url [https://provider-static.plex.tv/1/epg/channels/logos/gracenote/16617a15d293f6aeb593ae58c58a7d4c.png] (is local: 0 upscaled: 1)
Mar 27, 2021 14:39:45.729 [5160] DEBUG - Completed: [192.168.5.4:38872] 200 GET /photo/:/transcode?width=240&height=240&url=https%3A%2F%2Fprovider-static.plex.tv%2F1%2Fepg%2Fchannels%2Flogos%2Fgracenote%2F16617a15d293f6aeb593ae58c58a7d4c.png&minSize=1&upscale=1 (28 live) GZIP 14ms 12377 bytes (pipelined: 1)
Unfortunately, I don’t explicitly have de49463b77d15708d0b65aacd2c57f3a330228e0.png - I guess Plex doesn’t download them all every day and my logs only go back 2 or 3 days.
I get this too. In addition HD recording is hit and miss, mostly miss. Almost all of my recent recordings have been in SD.
At this point I don’t care to think how many hours of my life i’ve wasted fiddling around with plex live tv
@cire12 When I deleted and re-set-up DVR, and searching for ‘epg/channels/logos’ I can find .png lines for all channels except ITVHD which is '103 (ITV Central East HD) ’ in my case.
So LE2 isn’t pulling a logo for ITV HD ‘ITV Central East HD’
