THANK YOU @sa2000. Confirmed that everything is back to normal after a Guide refresh.
My recurring news airings are again populating in my DVR schedule list.
I let the Plex users on reddit know too
All us local news nerds are back in business ![]()
Thank you so much @sa2000 !!! Worked like a charm. Excellent debugging!
Thanks so much @sa2000 for the quick response and regular updates on this issue. Much appreciated and happy to see this was quickly resolved!
@sa2000
While my local news is now recording the date shown below the recording is now wrong and off by two days even though the file and XML show it should be 04-13 it is showing 04-11
I now believe this to have been the same EPG backend system issue that we fixed on Wednesday and the fix would get picked up after an EPG Refresh on the server
Gracenote EPG data coverage in Portugal is limited
The last time we raised the issue with Gracenote for Portugal EPG data, the response was that they only maintained data for a limited number of channels. This was provided and you can see it here Live TV EPG - The update you’ve been waiting for - #1314 by sa2000
If you have any issues with any of the channels they indicated as supported, let me have the details and I will refer to Gracenote but I would need a post code and which lineup/provider you are intending to use
Did you get any reply ?
I can see EPG data for channel 300 Sky Cinema Premieren HD on the Sky Q Lineup for your post code
Well, it would make it easier for me if I had the channel numbers to go with the channel names
I found these channels in the Sky Q lineup
| vcn | title |
| 302 | Sky Cinema Best Of HD |
| 304 | Sky Cinema Action HD |
and they both appear to have EPG Data
channel 302
and channel 304
For Amazon Prime Video (Sports Bar) I need to have the channel number and also a pdf file for the Sky Q channel list from Sky and if possible a url to the Sky Q list for Germany showing that channel and I will refer it to Gracenote
Yes, the error has been fixed in the meantime.
Thanks for reporting this.
I cannot see how this would have arisen. At the time of the recording the originally
Is it still happening ?
If it is, I would like some server logs - please ensure you have server debug logging enabled
One set of server logs captured 5 minutes after the end of a new recording
and the xml metadata then - please copy into a file and save as text file rather than getting a screenshot of the xml - please also get a download of the database through web help and troubleshooting page - you can send that to me by PM
and then refresh the metadata for that new recorded episode and get another set of server logs and metadata xml and another download of the database
We should not be attempting to update the EPG sourced metadata for recordings
The metadata xml you provided screenshot shows the item was added to the database at 23:32:14 GMT on the 13th which would have been just after end of recording but it was updated a day later at 12:50
Hi @sa2000 I’ve been experiencing a similar ongoing issue with wrong dates and dates that change when accessed (clicked on in the UI). It has been reported in this post: Date Wrong on DVR Recordings - the issue is still ongoing for me. I’m happy to provide more information or testing if you like. Thanks!
I noticed today that here in Los Angeles virtual channel 8.6 through 8.10 is missing from the guide. 8.1 - 8.5 metadata is there but it’s not automatically populating. Any chance you can get this over to Gracenote? See the attached photo.
That is a very old forum topic thread.
Yes I would like debug server logs and details of airings and zip code and lineup and channel number and channel name and I can investigate - similar diagnostics as I outlined here Live TV EPG - The update you’ve been waiting for - #1869 by sa2000 in addition to the channel number / channel name / lineup / show name / airing dates / media xml
I will refer the missing 8.6 to 8.10 channels to gracenote
For the other channels - 8.1 to 8,5 if they were added recently to the lineup., you will need to manually match
So tick the box for each channel to enable it and then in the drop-down on the right side find the equivalent channel in the lineup
I tried a zip code for Los Angeles and the Local Broadcast Listings does have these channels - so you can assign manually
8.1 : KFLALD (KFLALD (KFLA-LD) Affiliate: NewsNet)
8.2 : KFLALD2 (KFLALD2 (KFLA-LD2) Affiliate: Real America’s Voice)
8.3 : KFLALD3 (KFLALD3 (KFLA-LD3) Affiliate: American Classic Entertainment)
8.4 : KFLALD4 (KFLALD4 (KFLA-LD4) Affiliate: Biz Television)
8.5 : KFLALD5 (KFLALD5 (KFLA-LD5) Affiliate: Shop LC)
I have referred this to Gracenote
Any reply?
Note, I tried a Nottingham NG1 postcode, and a retune, and see this:
So, it can see 101 BBC ONE EMidHD.
However, it still believes the EPG data is 101 BBC1 (BB1LDH) - if I try and select 001 BBC1 (BBC1EM) instead, which it is, then I get the error screen below:
So, I cannot select BBC1 EM for 101 no matter what.
Please fix this @sa2000
@e10kstarfire For now you have to select 101, even though it says BBC1 London as the data from gracenote has not been updated for the new regional HD channels. Hopefully @sa2000 can chase up gracenote to get this fixed for each region.
The following (new) channels are missing in my EPG:
Lineup: Astra FTA
Country: Germany
Postal Code: 10115
Please note that the channel One Terra can already be found in TMS - channel ID 135131. The new Deluxe Music channels are also available there. Please kindly ask Gracenote to add the above mentioned channels. Thanks in advance. ![]()
