No change yet - program guide and channel description still missing for Channel 12.6 Circle in Binghamton, NY 13901 or nearby 13760
The ones that were missing thumbnails are now all showing fine, but I’ve found a pattern in it.
If I do the following:
- Go to Live TV > Browse
- Select the Shows > By Name view
- Scroll down to a show and select the Record option from the menu
- Schedule it to record
It appears in Recording Priority with a thumbnail as expected.
If instead I
- Search for the show name in the global search
- Click on the show in the Live TV (Tuner) section like this
- Schedule the recording
It appears in the Recording Priority with no thumbnail., but this appears some time later.
This only appears to be happening in Chrome (Safari is fine) when accessing via app.plex.tv, not when accessing it directly it is fine and mobile apps are also fine.
I am seeing this in the Chrome Developer Tools which looks related:
Access to XMLHttpRequest at https://192-168-***-***.*******************************.plex.direct:32400/photo/:/transcode?width=120&height=180&minSize=1&upscale=1&url=https%3A%2F%2Fmetadata-static.plex.tv%2Fd%2Fgracenote%2Fd612f24ee0205538823c1bc9afdbf1ea.jpg&X-Plex-Token=*********' from origin 'https://app.plex.tv' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource.
This was after recreating the Columbo recording via the search as above and losing the thumbnail That blocked URL appears to be missing poster. It looks like it is trying to use the internal IP address and this is being blocked by Chrome.
I can’t get the full logs now (I can recreate this later and get them).
Thank you very much for looking deeper and confirming it is the same issue seen in the diagnostics from @Olli
I don’t need any more logs and I am referring it to the Plex Web development team
still no updates… Eugene showing the wrong channels and newer ones not list at all. Does it really take years for Gracenote to update?
The previous response was that these were out of scope for their database. They had mentioned before that they are no longer adding low power stations.
I have asked Gracenote for the latest status on these two sets of channels:
K06QR-D (41.x) and K03IM-D (3.x)
Gracenote have responded re-stating their original responses that the channels from K06QR-D (41.x) and K03IM-D (3.x) are out of scope and are not going to be added to their database - at this time,
I am sorry. I do not know if it is because they are deemed low power stations but this is their final response
I’m not seeing the correct epg for the xfinity market I’m in. I should see the Xfinity - Brooklyn guide data for my zip code of 49249 but it will only show 3 stations having a match. If I change the zip code to 49201 (Xfinity - Jackson) the 3 stations will not show up with a match
if I try and add the second list it does not populate anything. I’m wondering if there are too many in the list as there would be over 1600 in the list at that point.
The 3 stations not showing up are in the last screenshot
Thanks for reporting your issue
I need to see the list of xfinity TV channels for 49249 and 49201
I managed to get a list for 49201 using Xfinity TV Local Channel Line-up and entering this for the street/zip code search 341 EDWARD JACKSON MI 49201
But i tried several street addresses for 49249 Jerome, MI and none found a supported lineup
Could you please give me example of one that relates to you for this lookup screen
I need an example for 49249
Do you have a list of all the channel numbers and channel names/callsigns for the channels from xfinity that your DVR tuner is receiving ?
Use the following address to browse channels for my area in the xfinity tool
11562 GRAND POINT DR JEROME MI 49249
The following is a list of channels that my HDHR cable box is picking up.
3 WLAJ
6 WLNS
7 WSYM
8 WTVS
10 WILX
12 WXYZ
13 WKAR
15 JTV
21 WTVG
24 HSN
25 QVC
41 CSPAN
75 HSN2
89 SHOPHQ
90 JTVINC
99 CBET
157 JTV
189 QVCHD
231 WLAJDT
232 WILXDT
233 WLNSDT
234 WSYMDT
236 WLAJDT2
240 WKARDT
287 WKARDT3
288 WKARDT2
290 WSYMDT3
293 WKARDT4
294 WILXDT2
295 WILXDT3
296 WSYMDT2
377 HSNHD
385 SHOPHQ
389 COMADSL
392 TBN
393 EWTN
395 WORD
396 DYSTR
400 IMPACSD
401 MC01
402 MC02
403 MC03
404 MC04
405 MC05
406 MC06
407 MC07
408 MC08
409 MC09
410 MC10
411 MC11
412 MC12
413 MC13
414 MC14
415 MC15
416 MC16
417 MC17
418 MC18
419 MC19
420 MC20
421 MC21
422 MC22
423 MC23
424 MC24
425 MC25
426 MC26
427 MC27
428 MC28
429 MC29
430 MC30
431 MC31
432 MC32
433 MC33
434 MC34
435 MC35
436 MC36
437 MC37
438 MC38
439 MC39
440 MC40
441 MC41
442 MC42
443 MC43
444 MC44
445 MC45
446 MC46
447 MC47
448 MC48
449 MC49
450 MC50
924 LO
989 CSPANHD
999 CBETDT
1006 WLNSDT
1007 WXYZ
1009 CBETDT
1010 WILXDT
1012 HSNHD
1013 WTVG
1014 HSN2
1023 WKARDT
1024 QVCHD
1047 WSYMDT
1053 WLAJDT
1056 WTVS
1096 COMADSL
1098 LO
1128 CSPANHD
1163 WKARDT3
1164 WKARDT4
1165 WKARDT2
1172 WLAJDT2
1188 WSYMDT2
1189 WSYMDT3
1192 WILXDT2
1193 WILXDT3
1550 MC01
1551 MC02
1552 MC03
1553 MC04
1554 MC05
1555 MC06
1556 MC07
1557 MC08
1558 MC09
1559 MC10
1560 MC11
1561 MC12
1562 MC13
1563 MC14
1564 MC15
1565 MC16
1566 MC17
1567 MC18
1568 MC19
1569 MC20
1570 MC21
1571 MC22
1572 MC23
1573 MC24
1574 MC25
1575 MC26
1576 MC27
1577 MC28
1578 MC29
1579 MC30
1580 MC31
1581 MC32
1582 MC33
1583 MC34
1584 MC35
1585 MC36
1586 MC37
1587 MC38
1588 MC39
1589 MC40
1590 MC41
1591 MC42
1592 MC43
1593 MC44
1594 MC45
1595 MC46
1596 MC47
1597 MC48
1598 MC49
1599 MC50
1657 DYSTR
1677 3ANGELS
1681 WORD
1682 IMPACSD
1995 CSCT
What the actual problem or inaccuracy is with any related screenshots: Missing Channel
The lineup name: Local Broadcast Listings
Channel number and channel name: 35.2 Story
Your country: USA
Postal code: 44333
Region/market: US/Ohio
Version of Plex Media Server in use: Version 1.32.3.7192
How long will these channels take to be added?
Still no data.
Gracenote have come back to say that these two channels are currently out of scope for their database
WNDU-TV channels 16.6 Oxygen and 16.7 GetTV
This has been referred to Gracenote
Thanks for the information
I have compared the DVR Tuner channels and the channel list from the Xfinity lookuo using the street address given by you and have submitted a request to Gracenote to correct the Xfinity lineup for USA Jerome, MI 49249
Requesting these channels to be added to the lineup
| Tuner vcn | Tuner Callsign | Xfinity vcn | Xfinity Channel |
| 3 | WLAJ | 3 | WLAJ |
| 6 | WLNS | 6 | WLNS |
| 7 | WSYM | 7 | WSYM |
| 12 | WXYZ | 12 | WXYZ |
| 13 | WKAR | 13 | WKAR |
| 233 | WLNSDT | 233 | WLNSDT (WLNS-DT) |
| 234 | WSYMDT | 234 | WSYMDT (WSYM-DT) |
| 240 | WKARDT | 240 | WKARDT (WKAR-DT) |
| 287 | WKARDT3 | 287 | WKARDT3 (WKAR-DT3) |
| 288 | WKARDT2 | 288 | WKARDT2 (WKAR-DT2) |
| 290 | WSYMDT3 | 290 | WSYMDT3 (WSYM-DT3) |
| 293 | WKARDT4 | 293 | WKARDT4 (WKAR-DT4) |
| 296 | WSYMDT2 | 296 | WSYMDT2 (WSYM-DT2) |
| 1006 | WLNSDT | 1006 | WLNSDT (WLNS-DT) |
| 1007 | WXYZ | 1007 | WXYZ |
| 1010 | WILXDT | 1010 | WILXDT (WILX-DT) |
| 1023 | WKARDT | 1023 | WKARDT (WKAR-DT) |
| 1047 | WSYMDT | 1047 | WSYMDT (WSYM-DT) |
| 1053 | WLAJDT | 1053 | WLAJDT (WLAJ-DT) |
| 1057 | QVC3 HD | ||
| 1163 | WKARDT3 | 1163 | WKARDT3 (WKAR-DT3) |
| 1164 | WKARDT4 | 1164 | WKARDT4 (WKAR-DT4) |
| 1165 | WKARDT2 | 1165 | WKARDT2 (WKAR-DT2) |
| 1188 | WSYMDT2 | 1188 | WSYMDT2 (WSYM-DT2) |
| 1189 | WSYMDT3 | 1189 | WSYMDT3 (WSYM-DT3) |
| 1192 | WILXDT2 | 1192 | WILXDT2 (WILX-DT2) |
| 1193 | WILXDT3 | 1193 | WILXDT3 (WILX-DT3) |
and also to have these channels checked out and corrected
I do not understand what ‘out of the scope’ exactly means. Would you please explain?
It is what Gracenote are saying - that at this moment in time they do not have these specific stations transmitted channels and at this time they will not get added to their database
Previously they have stated that they are no longer adding low powered stations to their database and will look into each specific request and make a decision as to whether it gets added or not
Can someone please guide me on this intermittent issue i’ve been having with the guide that I posted about nearly a month ago with as much information as I could demonstrating the issue?
@sa2000 Any further update? Seems such an easy fix yet taking ages to do.
WCBS 2.5 = Circle TV network
WZME 43.8 = Retro Television Network
WZME 43.9 = Heartland network
Your country: USA
Postal code: 06902
Region/market: US/New York City
I dont have BBC One HD either, it shows in the EPG, has no logo and when you try to view it i get a “cannot tune” error. This is having an effect on my recordings too as they fail and it wont record the SD channel (which does work).
I’ve tried everything from deleting the DVR, deleting the tv database even and going through the retune process, Selecting freeview etc. Nothing works and very frustrating.
Forgot to add:-
Country - UK
Postal code - ST6
Region/market - West Midlands
Version of Plex Media Server in use - Version 4.108.0
