Missing channels in plex live tv guide
@sa2000 I filled out the form. I technically live in the Philadelphia OTA market but the area i live in in Delaware is a sweet spot where we receive both Philadelphia and Baltimore channels. I don’t get any Baltimore guide data from the Philadelphia lineup and some Baltimore channels that I pick up have the same channel numbers as Philadelphia channels that I can’t pick up so I just get completely incorrect guide data for those. In a previous version of PMS the lineup I had gave me correct data for all the channels I could pick up. Since the update to the new program guide Philadelphia and Baltimore are separate and mutually exclusive lineups. We need a lineup that combines Philadelphia and Baltimore channels. I hope this can get rectified soon. Thanks!
What I can do is get your zip code added to the Baltimore area so you would have a choice of either Baltimore lineup or Philadelphia
I have arranged for channels to overlap between regions but if the channel numbers are the same but for different channels then that will not be possible
@sa2000 I’d be losing a lot of programming if I had to chose one or the other. What about having the channels overlap between the two regions where the channel numbers are not the same?
Channels 2.1, 2.2, 2.3, 2.4 and 2.5 all exist in Philadelphia and Baltimore. I can’t pick up the Philadelphia channels for these but I can also live without having those Baltimore channels in my lineup.
But channels 11.1, 11.2, 22.1, 22.2, 22.3, 22.4, 54.1, 54.2, 54.3 and 54.5 are unique to Baltimore and I pick them up. Can those channels be added to the Philadelphia lineup?
Pittsburgh Verizon FiOS lineup is missing channels too; like 780 Disney HD–which is completely unacceptable.
The loss of the channel could be the issue mentioned here New EPG and release - #917 by sa2000
I will check later today if it is.
Yes it is the same issue as the one I linked to. We are testing out the revised process for updating our guide data before making it available to the live service That channel together with a few others on your lineup do appear in the development environment
For Disney channel, you could see if channel 250 or 1729 give you the SD equivalent channel whilst the HD channel on 780 is unavailable
I filled out the form last week but the spreadsheet hasn’t been updated so not sure if you guys got the bug report.
Charleston, SC 29492
OTA broadcast guide
Missing 24.1 fox
Please fix ASAP. This is fox so the fact that it’s missing is a pretty huge gap.
channels should have come back today
@sa2000 you never acknowledged my last question. Is it possible to have the Baltimore channels that don’t conflict with Philadelphia added to the Philadelphia lineup?
Yes - I have been busy… I will suggest to our provider that we do that
I have now requested that these Baltimore channels get added to the Philadelphia OTA lineup
@sa2000 Much appreciated!
@joelkolb the channels listed in my post here Missing channels in plex live tv guide have been added to the Broadcast TV Philadelphia OTA Broadcast lineup and are available now. Please go through Live TV and DVR settings to match channels
@sa2000 I was able to add those channels now. Thanks a lot!
I am in the Rochester/Syracuse market and missing OTA channels
9.1 WSYR-HD
9.2 WSYR-2
9.3 WSYR-3
9.4 LAFF
from the station pull-down assignment. All 4 are on the left ready to be enabled (and come in strong directly via HDHomerun, but are missing the assignments in the right pull-down in Plex. I’ve tried different zip codes and currently using a zip in-between Rochester and Syracuse. I am running Version 1.18.0.1944, and filled out the form about a week ago.
I am in the (Yuma, AZ) - (El Centro, CA) _ USA area and missing OTA Broadcast channels. I am running Chrome, 4.8.4, Plex Web, Linux. My zipcode is 92243, El Centro, CA, USA I am curently only listing 12 OTA broadcast channels:
Current PLEX server setup:
2 DEVICES (HDHomeRun CONNECT)
4 Tuners CHANNELS
Missing Channels:
1.1 XHAQ HD
1.2 XHAQ
2.1 XHBM HD
2.2 XHBM
3.1 XHCTME HD
3.4 XHCTME
4.1 XHBC HD
5.1 XHMEX HD
7.5 CourtTV
10.1 XHMEE HD
20.1 XHEXT HD
20.2 XHEXT
54.3 TBD
54.4 Stadium
66.1 XHILA HD
66.2 XHILA
66.3 XHILA
66.4 XHILA
Manage Channels
DVR—Broadcast TV
(DST)
I am going to put a request for adding these “Broadcast TV Syracuse OTA Broadcast” channels into the “Broadcast TV Rochester OTA Broadcast” lineup - they do not clash with existing channels in this lineup
I have put the requests in for these channels
The channels have now been added to the Broadcast TV Yuma-El Centro (DST) OTA Broadcast lineup
The following channels have now been added to the Broadcast TV Rochester OTA Broadcast lineup
