I have submitted a request to have these 2 channels added to the Kabel Deutschland Brandenburg Digital lineup
With regards to auto mapping not working - Plex Media Server does attempt to map channels - I would need logs covering DVR setup to see why some are not auto mapped
For Home & Garden TV, it could be because the EPG channel name is HGTV (Germany)
EPG Problem - CBS Spectrum HD Portland Digital - The Young and the Restless. Yesterdayâs episode was labeled 12/17/19 in EPG and todayâs episode is labeled 12/17/19 - 12/18/19, which after recording shows as two episodes for 12/17/19 and I donât have to option to split them. Thursdayâs episode is labeled 12/18/19 - 12/19/19 which will also be a problem. Fridayâs episode is labeled correctly at 12/20/19.
I have the same problem with Young and the Restless on Verizon Fios Digital Philadelphia. I submitted a request via the form to have it corrected by the EPG provider.
Hopefully it gets corrected soon so my wife stops giving me grief. LOL!
Thanks for bringing this up. It appears that airing of the episodes in Canada was a day earlier and we are picking that date for the original air date causing the confusion. I have referred this to our EPG team. I can see that episodes for 20th December to 31st appear to have the right US original air dates
I can see these 2 channels on the Brandenberg lineup
I will request that 160 gets added to the National lineup - there is already a radio channel there but that is a general issue with this where radio channel numbers collide with TV - but manual assignment would work
So for this - it should get fixed once the âKabel Deutschland Brandenburg Digitalâ lineup has the channels you are waiting for
In this, is it the auto mapping that was wrong? or that the HD icon did not get removed after mapping to 602?
I do see both SD and HD channels available
Would like to know what the auto mapping was for
5043 KiKA HD
5049 KiKa
You say 5049 was mapped to the HD channel - and did you after that switch it to 602 Kika SD but the HD icon next to the mapping was sticky and did not get cleared ? - That could be a plex web issue
The following rbb channels appear in the Brandenberg lineup
So this will resolve itself once you move to the Brandenberg lineup
I do not know how feasible it would be for the national lineup having all regional channels - I will this as now
The national lineup would most likely need a lot of manual intervention for mapping. With the localized regional lineups I would expect be better automatic mapping of channels - of course if there are no channel numbers, it does make the mapping more difficult
date and time in UTC please - I canât see any Dead of Night or Dead of Winter when I got an extract for 503 for next 2 weeks. May be it is in German !
Is this the Kabel Deutschland Germany Digital lineup?
"title": "Panzer-Alarm im Westerwald",
Series "title": "Steel Buddies - Stahlharte GeschÀfte"
"start": "2019-12-21T20:15:00.000Z",
"title": "Showdown auf dem Highway",
Series "title": "Body Cam 911 - Polizeieinsatz hautnah"
"start": "2019-12-21T21:15:00.000Z",
"title": "Folge 2",
Series "title": "Body Cam Cops"
"start": "2019-12-21T22:15:00.000Z",
May be it was a late change and you had not refreshed the guide in time
Or may be there was an issue with overnight automatic refresh of the guide
(would need logs)
There is no information as to why. May be some error earlier on. The logs go back to 02:35am - may be errors occurred at the beginning of the scheduled task period or it could even be an error from previous day if the server has been running for a while.
I would suggest we increase the number logs - by adding this registry key LogNumFiles of type DWORD (32-bit) Value and setting it to a value of decimal 20. This needs to be created in the registry below HKEY_CURRENT_USER\Software\Plex, Inc.\Plex Media Server
After doing this restart the Plex Media Server so any residual issues would hopefully get cleared. Then capture the logs after this evenings scheduled tasks and hopefully there will be some clues
@rossinior Noticed a number of âError 12â codes logged for starting transcoder jobs. Wonder if this error code was also being returned for starting scheduled tasks
If it is a windows error code, then it would be
12 (0xC): ERROR_INVALID_ACCESS - The access code is invalid
Any system / application errors in the Application and System event logs that are out of the ordinary
