New EPG and release
Regarding the issues with Ask This Old House and This Old House first airings not being marked as new, I’m seeing the same issue with The This Old House Hour:
The airing on 4/2 at 11 PM EDT on 29.3 (ETVW) is the first in my market, but isn’t being marked as new. The airing on 4/3 at 12 AM EDT on 29.1 (SCETV) is the first HD airing in my market and should likely be marked as new as well.
My lineup is Broadcast TV Grnvll-Spart-Ashvll OTA Broadcast.
For what it’s worth, this series is configured to prefer HD and record new and repeat airings; so, the 4/3 HD airing is the one which it’s choosing to record (as expected).
EPG for The Young and the Restless, (Spectrum HD Portland, Maine Channel 13), appears to be hosed (Episode Numbering) as of today. Had been corrected in January and was perfect through Feb/March but now, not so much.
Thanks for the feedback - appears to be a mixture of New Indicator issues as well as episode numbering issues
I will refer these to our provider - an audit of 3 series is needed - as it appears there are some errors in originally aired dates as well
I looked at https://www.vermontpbs.org/schedule/ but they do not indicate if the airings are new
This is what we have in the EPG at this moment
What is the actual issue and what impact does it have ?
Looking at all airings for this show on 13 CBS the only bit I can see that is wrong is the originally aired date which for the 3rd April onwards is a day early and that is caused by Canada having these episodes airing a day early.
Are you losing recordings ? If you are, could you get me server logs with debug logging enabled beforehand for one of these recordings that is getting lost. Capturing the logs a few minutes after end
https://support.plex.tv/articles/201643703-reporting-issues-with-plex-media-server/
https://support.plex.tv/articles/200250417-plex-media-server-log-files/
I just was researching my upcoming shows and want to throw Nova into the list of shows that seem to be exhibiting the same behavior.
Latest Episode
NOVA-47x05-Cuba’s Cancer Hope does not appear on my recording list. Plex is set up to record only new airings. (same channels as This Old House).
Nor does next week’s 47x06 - The Truth About Fat
Thanks for the info - I presume what is wrong here is that the following two airings needed to have the “New” indicator set - is that right?
Wed 01-Apr-2020 21:00 Local Time - Cuba’s Cancer Hope
Wed 08-Apr-2020 21:00 Local Time - The Truth About Fat
Yup, sorry if that wasn’t clear in my initial post.
Thanks for the confirmation
I have referred the lack of the “New” indicator for the following airings to our provider
I have similar issues with This Old House. The Saturday airings are not marked as new and have the wrong episode number. Most episodes have no episode number or title. I have the same problems with Austin City Limits on the same channel. This is channel 32.1 WHUTHD in the Washington(Hagrstwn) lineup.
listings
Thank you.
I have referred both to our provider
Grande Clear Source
Channel 842 Nicolodeon
I’ve just noticed “It’s Pony” S/E data is a fubar repeating mess. There is zero point in putting S/E data if it is complete rubbish.
It creates two entries for the same day. This is after today’s recording, I renamed yesterdays episode so it would be correct. No Split option…
Mondays the EPG as well episode 4/3 - 4/6?
Tuesday’s EGP 4/6 - 4/7?
Thanks for the feedback. I am passing it on to our EPG ingestion engineering team. The issue arises when there is another country in the region with an earlier airing date - in this case it is Canada.
I have an open issue on this and it requires future development work
Thanks! But just to be clear, this just started two days ago…
I cannot check old Canada schedules for this so cannot tell if the earlier airings in Canada just started
Looks as though the EPG was corrected, everything appears to be back the way it was earlier this week. Thanks for the assistance.
It is 845. Lucky that number was close to 842 so not difficult to find in my dropdown)
The problem is that these airings are being broadcast by Nickelodeon as combos
I spent some time seeing what they are and they appear to be half hour airings of episode combinations
The schedule from Nickelodeon does show half hour airings and they do not appear to be giving correct episode numbers anyway
we are no longer matching with tvdb episode numbers for recordings, so whatever episode titles and numbers come through should get preserved
The channel name has been corrected - now shows as “The Country Network”
EPG data is now available for the channel
I am not aware of any changes that would have changed the original air dates for The Young and The Restless
If it is still ok, could you get me zip of a copy of the EPG database files
Copy out the 3 files with names starting
tv.plex.providers.epg.cloud- and zip the copied files
The files would be in the Databases folder
which by default is:
C:\Users\xxxxx\AppData\Local\Plex Media Server\Plug-in Support\Databases
Sure, DB attached. ThanksTV_DB.zip (8.3 MB)
