New Plex Guide Very Poor in UK
Our provider are having issues with their feed from the Channel 5 network and there is currently a lot of manual work. I will ask for an update.
Checking EPG data today - the earliest TBA is at the end of the schedule - on 23 May for channel 5
Similarly for 21 - Five US
and 31 - Paramount
For 30 - 5Star - it is 21 May
54 - 5 Select appears to earlier - 16th May - but it is a 5am one - which would be part of a Teleshopping block - so no real impact
Do you know might have caused the 85 minute quirk and why anything above that changed the schedule to move to the second half of the + 1 showing?
I can see that this episode was not sequenced. I have referred the omission to our provider
The airing for the 17th May is sequenced correctly as S3 E5
I just tested adding 90 minutes and it is working
May 13, 2020 11:48:44.204 [13212] VERBOSE -  * prefs[startOffsetMinutes] => 0
May 13, 2020 11:48:44.204 [13212] VERBOSE -  * prefs[endOffsetMinutes] => 90
May 13, 2020 11:48:50.288 [10200] DEBUG - Activity: registered new activity fdb3eca2-bf19-4d44-abe4-536b825ed73a - Recording
May 13, 2020 11:48:53.240 [10200] VERBOSE - Sufficient disk space: 13.58GB source file, 935.53GB capacity, 260.78GB available on "C:\Users\Public\Plex-Tests\Shows-Test-onlyRecordings\.grab"
May 13, 2020 11:48:53.241 [10200] DEBUG - Grabber: Saving recording to "C:\Users\Public\Plex-Tests\Shows-Test-onlyRecordings\.grab\520944116a2cd78a3337f54f3ad248cbd36bc01b-b79fcbfb64fa3ca58f3ef8e115327951a2cb9f4c"
May 13, 2020 11:48:53.312 [10200] DEBUG - MediaRecorderVirtual: setting stop time to 2020-05-13 13:30:00
Would really need server debug logs when this happens to investigate
DVR—Freeview Central (East) OTA Broadcast
Postcode: LE2
Killing Eve
BBC 1 AT 9:15PM on 17/05/20
Episode S3E5 is not marked as New. And it should be.
Postcode: LE2
Normal People
BBC 1 AT 9:00PM on 18/05/20: s1e7
BBC 1 AT 9:30PM on 18/05/20: s1e8
Both Episodes have no description or artwork.
Thanks - I can see the omission. I have referred this to our provider
Thanks for reporting this. There is artwork at the series / show level. But there is definitely no series or episode text. I have referred it to our provider
I found other issues but i filled in the form here: https://docs.google.com/forms/d/e/1FAIpQLSf0YIecSlA_pyZzmEttGeIT8ombGVJoIQB20Wa-YXHSv7vhhA/viewform?usp=sf_link
Is it still in use?
Thank you. I have referred this to our provider
Yes the forms are still in use but I have a backlog to process and mentioning it in forum post as well is best
Postcode: LE2
Gardeners’ World
BBC2 & BBC2 HD: S53E9 15/5/2020 @ 9:00PM
BBC2 & BBC2 HD: S53E10 22/05/2020 @ 9:00PM
Gardeners’ World has no specific Episode text, just generic text that is identical for each and every episode.
I am afraid this is awaiting some development work at our end. We are currently only using the series/show synopsis text for channels where the episode text is restricted to that channel only.
There are also complications because of regional channels and this is awaiting development work by our provider as well.
Thank you for the prompt reply.
Postcode: LE2
The Village
ITVHD: S1E3 @ 12:25pm on 17/5/2020
ITVHD: S1E4 @ 8PM on 19/5/2020
Episode text is generic, not specific to the actual episode.
Note: I assume this will be fixed when the root cause is:
There are two separate things here.
The main issue is that this was linked to the American series “The Village” and not the UK Welsh one, This has been referred to our provider as per my reply here
When that is fixed - it should then pick the UK series synopsis text and if there is episode text that is not restricted to ITV1 then that would get picked up. Otherwise - it would be pending the scheduling and completion of our future development work for this as well as our provider handling regional channels data
hfghkk
My guide shows the correct show now so its obviously:
@sa2000 - any update on this please? Is there someone else I should be contacting?
It is disappointing to see that the epg is still substandard. I also have to manually add extra time to films, struggle with an Android app that cannot properly schedule recordings oh yeah and tolerate a Plex server which has a broken commercial skipping feature!
Postcode: LE2
Killing Eve
BBC1 HD: S3E6 @ 9:15pm on 24/5/2020
The Episode is not mark as ‘New’. It should be.
Thank you for highlighting this is still wrong.
I have flagged it to our provider
