Still possible off topic but reverted to previous version and the problem disappeared.
Ditto
So now I’m giving my feedback after some tests. Yes, it really does seem to depend on whether “ViewstateSync” is activated. BUT it only seems to cause problems if it is activated when the PMS starts. If you activate it after the PMS has started, the server doesn’t seem to crash.
How I “tested”:
10:26 - sync deactivated under the old version 1.40.4.8679
10:27 - update to version 1.40.5.8854
11:38 - new version still runs without problems and crashes
11:38 - sync reactivated, PMS continues to run without problems
12:26 - PMS manually stopped by me and restarted (with sync still activated)
12:37 - PMS crashed
12.39 - PMS started again manually
12:46 - PMS crashed
Hm, in retrospect I realize that I could have tested what would happen if I switched off synch on version 1.40.5.8854 shortly after the server started (i.e. before the crash) - whether that would have prevented the crash.
Regardless, the old version 1.40.4.8679 is now working again and will stay there until a new update because syncing is important to me ![]()
If you need the log files for the “test period” 10:26 to 12:46, please let me know ![]()
Hey guys,
I am facing the same issue, right now testing if deactivating the “state sync” feature will help.
Question: does every user, who is having access to the server, need to deactivate this feature in his account settings? I have a couple of shared library accesses open, I am wondering if I have to close them until the issue is fixed.
Question2: Is there a good resource where I can understand how to revert back to an older PMS version on my Synology? Simply “synopkg install” of course fails and I wanna be careful to not lose my settings. Don’t want to waste time settings things up from scratch.
Thanks in advance!
The server owner must deactivate Sync View State & Ratings.
Unclear if others with access must also do so (I’ve not seen anything definitive either way).
View State Sync runs when PMS starts and every 30 minutes afterward.
You can look in Plex Media Server.log (and .1.log to .5.log) for entries with ViewStateSync.
Here’s a portion of the log entries when it runs (I deleted some lines with user names):
Aug 26, 2024 14:09:06.820 [140281052777272] DEBUG - [Req#c05/ViewStateSync] Starting
Aug 26, 2024 14:09:09.232 [140280985287480] DEBUG - [Req#c05/ViewStateSync] Sending state
Aug 26, 2024 14:09:09.232 [140280985287480] DEBUG - [Req#c05/ViewStateSync] All state sent
Aug 26, 2024 14:09:09.232 [140280985287480] DEBUG - [Req#c05/ViewStateSync] Getting state
Aug 26, 2024 14:09:09.297 [140280985287480] DEBUG - [Req#c05/ViewStateSync] Reading 0 states
Aug 26, 2024 14:09:09.297 [140280985287480] DEBUG - [Req#c05/ViewStateSync] Done getting states
Aug 26, 2024 14:09:09.297 [140280985287480] DEBUG - [Req#c05/ViewStateSync] Finished
You must uninstall the current version then install the earlier version. Synology does not support direct fallback. See FAQ 8: Uninstalling PMS - Reverting to a previous version.
Thanks for the quick response!
Yes, I’ve had similar entries on my end, including other user names, not only mine as server owner. Names of users which I shared the library with. From that perspective and since the “sync state” setting is an account setting (not server related setting), I believe all users must deactivate it.
I kicked out all of my library shares to all users for the time being and have a cronjob which will notify me as soon as PMS crashes. If it survives the night, I will add the shares again and check. If I find a definitive answer, I will let everyone know.
Thanks for the reference, very helpful!
Follow up: Every user who has shared access to the library needs to have the “sync state” feature deactivated. My PMS was running the whole night without issues but after adding the shares, I see again ViewSyncState entries of other users in my crash log.
I will revert to an older PMS and wait for the official fix. There is no proper way around.
Thanks for the update.
Which PMS version did you test this with? The problem originally occurred with version 1.40.5.8854. In the meantime there was also version 1.40.5.8897 and a beta version 1.41.0.8911. Are versions 1.40.5.8854 and 1.41.0.8911 also affected by the problem?
I was facing first minor crashes with 1.40.5.8854 and then heavy crashes with 1.40.5.8897. The tests I did with deactivating the “state sync” feature was on 1.40.5.8897.
I am now back at 1.40.4.8679 which I know was working fine and is now proven to run stable at my end.
OK, thanks. So there’s no reason for me to try the newer version 1.40.5.8897. Does anyone have experience with the beta version 1.41.0.8911? Does this also cause the crashes?
Last stable Plex Server Version is 1.40.4.8679
We have same or similar problem on Nvidia Shield.
Ok thanks. Yes, I’m currently running version 1.40.4.8679 (again). I was just hoping that the beta 1.41.0.8911 would no longer have the problem since @ChuckPa mentioned above that the problem might be fixed in version 1.41.0…XXXX
Try it and tell us… ![]()
Oh no thanks, as you can see above I have already tried a lot and done a rollback several times (and every time I was afraid that something would go wrong during the rollback) ![]()
Version 1.40.4.8679 is fortunately running so I will just wait until there is a (tested) stable and working version ![]()
I ran a quick (15 min) test with a DS414 running 1.41.0.8911.
1.41.0.8911 is affected, but in a different manner.
If the server libraries are not shared with others, PMS does not crash when ViewStateSync runs (the server owner has it enabled).
If the server libraries are shared with another Plex account, and the server owner and other account both have ViewStateSync enabled, PMS will still crash.
So… with View State Sync enabled,
- Share with others? Use 1.40.4.
- Don’t share? Use 1.40.4 or 1.41.0 beta.
@Corsolander could you tell me how you enabled the protocol center to show Plex start and stop messages? By default they are not shown on my side. I had to script my own monitoring…
Gruß,
Same issue after update to 1.40.5.8921 over DSM6 in DS414. I have shared some libraries with family, I disabled state sync, uninstalled last version and installed 1.40.5.8897 and enable state sync. By now, it seems that works after more than 10min. I let it all the night and tomorrow review PMS status, if not, I will rollback to 1.40.4.8679 until stable 1.41 appears.
Thanks for your reports, they help me to make it usable at least…
Finally it didn’t work and I was forced to rollback to 1.40.4.8679 this morning. From then, any issue.
I’m just wondering why, after the problem became known 3 weeks ago, the faulty update 1.40.5.8854 was still “recommended” as an update in the clients for days and the subsequent updates 1.40.5.8897 and 1.40.5.8921 that followed (and still contained the same error) were also displayed as “recommended” updates. Were the last 2 updates not sufficiently tested or were they still aware of the error but released anyway? There are certainly still a number of old Synology NAS with ARM v7 processors out there and it will therefore certainly affect many more systems than the “few” people who have reported here in the forum. Why not withdraw an update with such a (pretty serious) error and continue with the technical status of version 1.40.5.8854 until the error has been finally eliminated?
