I’m sorry, why is it correct to label “The Jellies (2017)” as “The Jellies (2019)” because season 2 aired in 2019? Original air date of an individual episode is irrelevant to identifying the series as a whole. This affects directory structure and would make an insane mess if done similarly for every show.
This is not correct:
The above is what I accumulated before and then after the epg switch. This should be top level “The Jellies (2017)”, “The Jellies (2019)” top level directory should not exist.
One good thing is I updated to 1.16.4 just now and at least it isn’t scheduling every episode to record anymore.
That may have been episode sequencing errors that got corrected after the 11th data
I have checked all episodes for periods I have access to schedule and episode numbers AMC HDTV (East) - TV Listings Guide and all episode numbers match
ftwd got fixed by the provider in time. Future airings look correct.
Oops sorry, yeh, whatever tvdb says for Aerial America is good. Thanks for looking into those. I see if I notice any other inconsistencies in my recordings when I have time.
I’m not finding it too bad. The main two things you have to do to are:
Check after booking a recording that it’s actually scheduled. The “New/Repeat” flags are messed up for a lot of channels (even BBC1) so you often have to select “New and Repeat Airings”.
Do manual EPG refreshes. I just don’t trust the auto-refresh yet
