The json outputs from the HDhomerun are attached
HDhomerun_json_files.zip (600 Bytes)
Thanks.
I have referred the problem to the development team. For some reason the tuner capture is not starting and then we report an error 30 seconds later.
There are similarities with what is in the logs from @Taddeusz on this forum topic DVR Stopping Recording After 30 Seconds
I have a pre-release beta build available for you to try. Not been able to reproduce the problem. Could you tell me which download package you use for the install?
Ubuntu 64 bit
I have the same problem with Windows and the problem only happens with HDhomerun quatro(my HDhomerun connect works perfectly) for what I can understand. (Itâs been a problem for months now)
Iâm also getting this issue from time to time. Iâm running the latest beta version of Plex Media Server on Ubuntu 18.04LTS with 3 x WinTV DuoHD receivers. It definitely is a little bit of a pain, especially when it opens a Tuner even after its shown the error occurred.
Same issue here. As soon as I click on a Live channel, I see a message âRecording Live TV - Sessionâ on the Plex server and âUnable to tune channelâ
How do I got about getting the pre-release beta to test for ubuntu 64 bit?
It has now been released as Plex Media Server Beta 1.13.8.5388
Same issue confirmed for me tonight. Win10, usb hauppauge dual tuner (plex supported). Latest version of PMS.
Same error. Restart server. Works for first channel, then switch channels it fails. Also it wouldnât play HD channels by default so removed the SD channels, now error comes up straight away.
I updated, and I still cannot tune channels, didnât have a chance to grab logs I will try to tonight.
could you see if it is as stated by @xf84 that the first tune is ok but subsequent ones fail
Would like logs of the failures on 1.13.8.5388 preferably after tried a restart of the server and a clean start
I will get logs as you stated hopefully tonight,
To give you more info:
2.tried to tune a channel on the nvidia shield through plex, wouldnât tune
tried to tune a channel on my PC (different pc from PMS but on the same local network), and I was able to tune a channel.
I tried to change the channel on the same PC and i wouldnât change
Tried tuning again on nvidia shield still wouldnât tune
Tried tuning a channel on my iphone, still wouldnt tune.
Again I will restart the PMS later and try to tune and message you with the logs.
Thanks - when doing the tests please note down the times for each and as you are getting different outcomes from different client apps please separate the tests and have a server restart between each client app tests and please also try to get logs from the apps as well
Can you tell me what the the filepath is on android tv for the plex app logs? I can ftp into the shield and grab the logs pretty easily from the shield.
I can tell you the path for the Plex Media Server logs if it was running on the nVidia Shield. But for the Plex client app on the nVidia Shield - it is network logging, enabled in advance via settings and then obtained through a browser via endpoint :32500/logging and all displayed text selected and copied to a text file
See https://support.plex.tv/articles/201573117-android-android-tv-fire-tv-logs/
I sent you logs in the message you sent me a few days ago, i have logs from the PMS and also from the nvidia shield client app.
Any updates?
It was in my backlog - looking at the logs now
The symptom and errors in the log are the same in version 1.13.8.5388 as was seen in your previous logs. I have already referred this to the development team
