sa2000
August 18, 2020, 1:48pm
61
martijn12345:
There is no folder named Plex in ~/Application Support/
There is a folder called Plex Media Player in ~/Application Support but that does not seem to have any log files. (As previously mentioned, this software works fine, even its outdated)
There is no folder called Plex Media Server on this computer, as itâs not my server (runs on linux)
Thanks. Lets try and launch the Plex for Mac app in terminal and see what errors come back
So after download from plex.tv/downloads and moving to the /Applications folder, start a terminal session and type in
cd /Applications
./Plex.app/Contents/MacOS/Plex
See if the Plex app launches and if any errors show up in terminal and any logs get written to
sa2000
August 18, 2020, 3:08pm
63
I expected errors or the Plex app launching
Could you list file permissions
so getting
cd /Applications
ls -ail
and then
cd /Applications/Plex.app/Contents/MacOS
ls -ail
and also
ls -al ~/Library/Logs
When you launch it through terminal with the following, does Plex show in the Activity Monitor as a running process ?
cd /Applications
And could you see if any logs got created within
~/Library/Logs/Plex
sa2000:
cd /Applications
ls -ail
"2909964102 drwxr-xr-x@ 3 martijn admin 96 Aug 14 13:45 Plex.app"
and then
Copy to clipboard
ls -ail
" martijn@Martijns-iMac MacOS % cd /Applications/Plex.app/Contents/MacOS
martijn@Martijns-iMac MacOS % ls -ail
total 2056
12909964106 drwxr-xr-x@ 4 martijn admin 128 Aug 14 13:45 .
12909964103 drwxr-xr-x@ 8 martijn admin 256 Aug 14 13:45 ..
12909964108 -rwxr-xr-x@ 1 martijn admin 758528 Jul 29 20:01 Plex
12909964107 -rwxr-xr-x@ 1 martijn admin 287280 Jul 29 20:01 Plex Transcoder"
and also
Copy to clipboard
"drwxr-xr-x 9 martijn staff 288 Aug 18 20:51 Plex"
When you launch it through terminal with the following, does Plex show in the `Activity Monitor` as a running process ?
Copy to clipboard
cd /Applications
`~/Library/Logs/Plex`
Indeed new log files are created, but they are also empty just like the previous ones
sa2000
August 19, 2020, 12:45pm
65
Thanks - so the application is probably exiting just after creating the empty plex.log file
After you launch it in terminal and it hangs - does the plex app show as a running process in Utilities / Activity Monitor ?
could we check the permissions and ownership of directory where the app creates its application data area
ls -ail ~/Library
and
ls -ail ~/Library/Application\ Support
and in these directories - are there any diagnostic / crash reports that get created the time you launch the plex app ?
~/Library/Logs/DiagnosticReports
~/Library/Logs/CrashReporter
There is a new download now - you could also try that
I ran it again from terminal, and took a screenshot. It does seem Plex is running.
with ls -ail ~/Library and ls -ail ~/Library/Application\ Support I am not sure what folders we are looking for. There are many⊠None are called Plex. Please specify what we are looking for.
There is no relationship between running Plex and any report in ~/Library/Logs/DiagnosticReports it seems there isnât even a folder called ~/Library/Logs/CrashReporter on my mac.
sa2000
August 19, 2020, 1:42pm
67
for the first ls -ail ~/Library I just want to see the line for Application Support in case its owned by root - so just one line from that output
for the 2nd - just pick the first two lines plus any other folder - first?
Is the home directory for the user account relocated ? or all internal default drive
sa2000:
ls -ail ~/Library
alright. First command:
12886817516 drwx------+ 113 martijn staff 3616 Aug 6 16:51 Application Support
Here a bunch from the second command:
12886817516 drwx------+ 113 martijn staff 3616 Aug 6 16:51 .
12886817105 drwx------@ 105 martijn staff 3360 May 19 08:24 âŠ
12886817517 -rw-râr-- 1 martijn staff 0 Dec 24 2017 .ACCC_Lock
12886817519 -rw-râr-- 1 martijn staff 0 Dec 24 2017 .ADCS_Lock
12886817520 -rw-rârâ@ 1 martijn staff 14340 Aug 18 19:51 .DS_Store
12886817521 -rw-rârâ@ 1 martijn staff 10 Nov 10 2014 .Shadowland5.6
12886817518 drwxrwxrwx 2 martijn staff 64 Dec 1 2015 .dcf
12886817523 -rw-râr-- 1 martijn staff 512 Nov 20 2016 .syssettings12a239c8044f4
12886817522 drwx------ 17 martijn staff 544 Oct 8 2019 AddressBook
12886821000 drwxr-xr-x 28 martijn staff 896 Aug 31 2019 Adobe
Nothing has been relocated, itâs all where itâs supposed to be by default.
sa2000
August 19, 2020, 3:55pm
69
Thanks - so the binary files showed a user group of âadminâ
total 2056
but âApplication Supportâ is user group âstaffâ
Could you delete the binary and install using âstaffâ group - I am not a Mac OS expert - not sure how that arose
sa2000
August 19, 2020, 3:57pm
70
With regards to the â+â appearing in here, could you repeat this adding -e option
so
ls -aiel ~/Library
Volts
August 19, 2020, 6:00pm
71
Mine matches his, at least regarding those permissions.
Applications (including âPlex.appâ) that I have installed in â/Applicationsâ are group âadminâ.
The directory â~/Library/Application Supportâ and contents are (with few exceptions) group âstaffâ.
My primary gid is 20/staff.
I am a member of 20/staff and 80/admin.
Martijn, I may have asked this before - have you tried creating another admin user account and opening Plex in that account?
Okay⊠we are on to something here. I have another admin user, which I never really use, its been created for maintenance only. I opened Plex in there, never done that before, and it just opens, im not logged in or anything but the app starts.
I switched back to my usual user account, it still does not start. So its not solved but maybe this helps pointing out the issue.
With regards to the + I ran ls -aiel ~/Library this is what I got.
"12886817516 drwx------+ 113 martijn staff 3616 Aug 6 16:51 Application Support
0: group:everyone deny delete:
sa2000
August 20, 2020, 5:28pm
73
Interesting that the Plex app launches in another mac account.
The extra info we got with the -e argument to ls, I understand is normal
As the process appears to hang on launch in the martijn after creating the empty plex.log file, we could see if a forced process dump has any clues
So you could try to launch again in terminal using your normal mac account and then when it hangs, open âActivity Monitorâ
Double click the proc -> sample button in the lower left
and save the process dump
Okay, here is the sample Sample of Plex.txt (72.2 KB)
sa2000
August 21, 2020, 10:55am
75
Thank you. Does the same happen with version 1.17.0 ?
https://downloads.plex.tv/plex-desktop/1.17.0.1376-439f8b7f/macos/Plex-1.17.0.1376-439f8b7f-x86_64.zip
Could you repeat the above test and get me sample process dump for 1.17.0 - captured as this time - after a few minutes of launch in terminal
And could i get a list directory of the logs directory to show last modified time for each file
ls -ail ~/Library/Logs/Plex
Here by the sample process dump for the newly installed 1.17.0
Sample of Plex 2.txt (72.1 KB)
And the requested list:
martijn@Martijns-iMac /Applications % ls -ail ~/Library/Logs/Plex
total 8
12909365675 drwxr-xr-x 9 martijn staff 288 Aug 21 21:43 .
12887123236 drwx------+ 39 martijn staff 1248 Aug 14 06:42 âŠ
12910204367 -rw-râr-- 1 martijn staff 1310 Aug 18 19:56 Plex Logs.zip
12910453355 -rw-râr-- 1 martijn staff 0 Aug 21 21:43 Plex.log
12910453288 -rw-râr-- 1 martijn staff 0 Aug 21 21:42 Plex.log.1
12910412393 -rw-râr-- 1 martijn staff 0 Aug 21 13:26 Plex.log.2
12910318848 -rw-râr-- 1 martijn staff 0 Aug 20 06:45 Plex.log.3
12910281774 -rw-râr-- 1 martijn staff 0 Aug 19 19:53 Plex.log.4
12910230911 -rw-râr-- 1 martijn staff 0 Aug 19 06:39 Plex.log.5
sa2000
August 21, 2020, 3:00pm
77
Thank you very much - I have added this to the diagnostics that I have referred to our Plex app development team
It is probably some early error that is not getting logged
@sa2000 Thanks for all the help so far. Any idea how long these matters usually take?
sa2000
August 25, 2020, 2:20pm
79
I am sorry but it is not possible for me to say. I have asked the development team
Volts
August 25, 2020, 3:17pm
80
Considering Plex works for you as a different user, I still think the best hypothesis is permissions/privileges for your user or on your home directory.
Until recently, Apple had a support page for how to reset user permissions. Oddly, I couldnât find it - and it turns out they recently removed it entirely. I suspect that in Apple-think, it means people arenât supposed to have permissions problems.
Hereâs the last version that Apple had up; it suggested Recovery Mode and a repairHomePermissions command, followed by an in-place reinstall . That seems like a BIG shotgun.
Resolve issues caused by changing the permissions of items in your home folder - Apple Support
Before that, these were the instructions for a long time. This is much less intimidating and seems like itâs still worth trying:
