Ok so was it because I made the directory in bash instead of through the DSM?
Yes. you need DSM to sanction the shared folder for me to query against.
Sounds good. Just made it in the DSM and moving the Library file to it through Bash. Hope that will workā¦
This worked like a charm, thanks youāre a lifesaver! What an amazing Plex Support God. Lol
Ok how can I verify it worked? I kjnow have a PlexMediaServer shared folder. But when I open Plex I still donāt see any indication that the old metadata or history is in there.
Which package did you install?
Did your installation take an appreciable amount of time?
I donāt think it took a terribly long timeā¦
I picked the second file.
If there is still data in the Plex share then it did not migrate.
You must have forgotten to Uninstall + Erase the errant DSM 7 installation perhaps?
Yep. majorly something wrong.
- verify case of the shared folder name on the file system?
Plex? - verify you did Uninstall + ERASE option of the initial DSM 7 package ?
Please also confirm with me which package weāre using here.
Plex.tv/downloads is the old structure.
Forum Preview is the new.
The two are not compatible EXCEPT the new scripting can move from the old location automatically.
Please attach the Migration.log (if it exists ā but I donāt think it does) in a ZIP file
Yes I believe when I uninstalled the DSM verson of Plex I chose to erase everything with it. Plex folder does have a capital P
I got the package from DSM 7 - Packaging 2.0 (PMS 1.24.2.4973) - Release information - #2
there is no migrations log.
If you have no Migration.log then it didnāt migrate.
This is confirmed by the data still being there.
This established, It will not overwrite an existing installation which is why I require the operator intervention to āEraseā the old data when uninstalling (safeguard)
Therefore, did you remember to delete the PlexMediaServer shared folder through DSM ?
yes and it came back with the new install.
The one which came back with the new installation is that which was DSM 7 created. It belongs and has proper ownership.
You, as administrator (only) should see there is an AppData directory` along with a ton of Warning files
If you want to migrate this manually, the process is as it seems:
- Stop PMS
- Perform a manual migration
sudo bash
cd /volume*/PlexMediaServer/AppData
rm -rf "Plex Media Server" <-- this is the errant / empty one
mv "/volume1/Plex/Library/Application Support/Plex Media Server" .
chown -R PlexMediaServer:PlexMediaServer ./Plex\ Media\ Server
donāt miss the dot in the
mvcommand
from this point on, you canāt use the Plex server on Ubuntu without creating a new Preferences.xml file (new server ID number set)
Go to each of the shared folders containing media. Make certain System Internal User PlexMediaServer has permission to read the shared folder(s)
Start the NAS PMS in Package Center.
Open the NAS by LAN IP address http://ip.addr.of.syno:32400/web
Stop the scanner if itās running.
Settings - Server - Library
Turn off ALL automatic library functions (you need to change the media locations)
For each of your library sections
a. EDIT the library section
b. ADD the new Synology location ā DO NOT delete yet
c. OK
d. Observe as PMS scans each section and refreshes the location. You will likely see a ā2ā indicator on the poster.
e. When done, EDIT the section again.
f. REMOVE the old Linux location
g. OK that
h⦠Observe another scan as the dupes are removed
i. When complete ā Empty Trash, Clean Bundles, Optimize Database
j. Repeat the above for the next library section to update.
k. When all are done, re-enable the automatic library settings as you had them.
Welp⦠I have totally hosed this. I got it installed, logged into my account but it doesnāt recognize the server. I uninstalled and created a new Library name to maybe start from scratch but canāt get that to recognize it either. Itās a 1520 and just updated to DSM 7.
All is not lost.
First step. letās get it recognized.
- Uninstall the Plex app ā KEEP option
- Download from Plex.tv
- Manual install WITH āUse Plex Claim Tokenā
a. Click the āGet Plex Claim Tokenā hyperlink
b. Plex.tv will open in a new tab
c. Click āCOPYā
d. Switch back to the Syno window
e. PASTE theclaim-xxxxxstring into the window
f. click NEXT - Click through taking the defaults and let it install
- It will spin 15-30 seconds while the installer talks to Plex.tv and PMS.
- It will then finish install and tell you the server has been claimed to your Plex username.
Now you can open and find it
Thanks. Thatās exactly what I just did using : PlexMediaServer-1.24.2.4955-d26a2afaa-x86_64_DSM7.spk. When it got to step 6 it was looking for me to start adding folders.
I will uninstall and try again. Thx
Follow the steps here, donāt overlook any of them. Itās a permissions issue.
ALL:
I am going to comment on that How-To.
I would NOT give PlexMediaServer FULL CONTROL of my media and Iām the engineer!
- Give READ ONLY unless you intend to write
- Give READ/WRITE for those places you want to save DVR files
IF you give Full Control
-and-
You leave āAllow Media Deletionā enabled in your Library settings (which is default)
-then-
ANYONE can click āDeleteā after watching your content.
Is this what you want?
This is Linux, and DSM 7 is restrictive. We all need to take some time to adapt to it before resorting to a āNo Holds Barredā posture.
Wouldnāt you agree?
It is your machine and you can always do what you want but I think this is a reactionary step to not understanding what happened in DSM 7.
The same reactions occurred in PMS 1.15.4.994 (DSM 6) when PMS was no longer an Administrator on the box.
Apologies, Iāve been at this hours trying different things Iāve seen online and in these forums. Just trying to get a fresh install of PMS on DSM 7. Canāt get it to run. Log file below. Any help is MUCH appreciated. I have followed all the instructions Iāve seen to start fresh and nothing has worked. Thanks.
Aug 28, 2021 21:42:24.116 [0x2e83fd48] INFO - Plex Media Server v1.24.2.4955-d26a2afaa - Synology DS215j armv7l - build: linux-armv7neon synology-dsm7 - GMT -04:00
Aug 28, 2021 21:42:24.117 [0x2e83fd48] INFO - Linux version: DSM 7.0.41890-0, language: en-US
Aug 28, 2021 21:42:24.117 [0x2e83fd48] INFO - Processor Arm
Aug 28, 2021 21:42:24.117 [0x2e83fd48] INFO - Compiler is - Clang 11.0.1 (https://plex.tv e0c29d5827bc4eaaa2ceb882cbeed224b0960173)
Aug 28, 2021 21:42:24.118 [0x2e83fd48] INFO - /volume1/@appstore/PlexMediaServer/Plex Media Server
Aug 28, 2021 21:42:24.122 [0x2b5ade90] DEBUG - BPQ: [Idle] -> [Starting]
Aug 28, 2021 21:42:24.127 [0x2b5ade90] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.35.5, threadsafe=1
Aug 28, 2021 21:42:24.128 [0x2b5ade90] DEBUG - Installing Library Database from ["/volume1/@appstore/PlexMediaServer/Resources/com.plexapp.plugins.library.db"] to ["/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db"]
Aug 28, 2021 21:42:24.128 [0x2b5ade90] ERROR - Couldn't copy file "/volume1/@appstore/PlexMediaServer/Resources/com.plexapp.plugins.library.db" to "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db": Invalid argument
Aug 28, 2021 21:42:24.402 [0x2b5ade90] DEBUG - Running migrations. (EPG 0)
Aug 28, 2021 21:42:24.402 [0x2b5ade90] ERROR - SQLITE3:(nil), 1, no such table: schema_migrations in "select version from schema_migrations order by version"
Aug 28, 2021 21:42:24.405 [0x2b5ade90] ERROR - Database corruption: sqlite3_statement_backend::prepare: no such table: schema_migrations for SQL: select version from schema_migrations order by version
Aug 28, 2021 21:42:24.405 [0x2b5ade90] ERROR - Error: Unable to set up server: sqlite3_statement_backend::prepare: no such table: schema_migrations for SQL: select version from schema_migrations order by version (N4soci10soci_errorE)
