Plex Media Server - Synology DSM 7 Preview - Issues ( Archive )
Ran into this, too. Was instructed to download the package from plex.tv and manually install.
My steps to a successful installation were:
  1. Didn’t do any research and just installed DSM 7 since I saw that Plex was a supported package
  2. After DSM upgrade, package center reported Plex was in need of “repair” so I clicked the button
  3. Received message saying I needed to grant the PlexMediaServer Internal User read/write access to my existing Plex shared folder
  4. Did so, chose repair again, and waited for a while
  5. Package center reported that the repair was unsuccessful
  6. Came here and found this thread, and read. OOPS that should have been step 1
  7. Small discrepancy in some instructions that say PlexMediaServer needs read/write to Plex Shared folder, versus full control. Went ahead and gave it full control.
  8. Read that I needed to uninstall the DSM 6 Plex package I had from old package center before upgrade (I used uninstall only). Great! Done.
  9. Cannot find Plex in the package center to re-install it, wtf
  10. Come back here and read some more
  11. Oooookkkaaayyy someone said to use the package from plex.tv
  12. Proceed to research the CPU of my Syno
  13. Proceed to research whether my intel CPU on my Syno is 32-bit or 64-bit
  14. Download and install correct Plex package from plex.tv
  15. Chose Normal Installation, use PMS internal storage for log files
  16. Received message asking me to grant permission to media files
  17. Granted read/write permission to applicable share
  18. No clocking, no “installing” messages or waiting or anything. At this point, I’m confused as to whether it was successful, but package center reports it’s installed
  19. Hesitantly open it up with cautious optimism
  20. Everything working wonderfully, and much faster than on DSM 6
  21. Thanking my lucky stars (and team members/other posters here) that I sort of stumbled into a successful upgrade/migration
Thank you!
Hello.
What’s the proper way to upgrade the PMS package from 1.23.3.4600 to 1.23.3.4707?
I’m getting this options and I thought that you only needed to do it the very first time you install it on DSM 7
I reinstalled Plex on DSM7. But I can’t find the media data in my video folder to integrate it into the Plex
I gave the Plex internal system user the right R / W on the video folder. But when integrating in Plex I see the video folder but no other folders that are actually there.
I’ve tried a lot but nothing has helped.
I have two sub-folders in the video folder for films and series. I do not see this.
plex
Just a quick question. Noticed that Plex for DSM7 has been updated 2 days ago ( 1.23.4.4775-b7e0c30f2), but does it still mean that the process of upgrade and permission needs to be followed as posted here on the forum or has there been an automated process once you upgrade from DSM6 > 7?
tnx!
@Rusty03 and all following here:
Once you’ve performed the migration from DSM 6 → DSM 7
Everything returns to normal. :slight_smile:
Migration is a One-Time task.
Standard update / upgrade is performed. There are no special tasks at this point unless you wish to make any changes – which I present in the Upgrade GUI pages.
@buck14
As just stated above, I give the option to change where log files are kept. By default, I keep whatever you have defined.
If you don’t want to change the logging , just “Next” to click through this page.
So my issue since the beginning is/was that the user “PlexMediaServer” was not existing under the “system internal user” list. The only way I had to fix this was to “reset” my synology, reinstalled DSM 7.0 and after installing the Plex package for DSM 7. Only now I see the user, but of course it was a fresh new install so all my server settings, database, etc was gone. So I uninstalled it, installed again and pointed to the share folder that I had previously with all my server folders (not media), was able to change the permissions accordingly and migration went through flawlessly.
Bottom line my main issue has always been the user “PlexMediaServer” which never existed or was created with the migration from DSM 6.0 to DSM 7.0, not sure when it should be created.
P.S.: all working as before with DSM7.0 and Plex for DSM 7.0
thanks
@gjbarradas
DSM 7 creates everything.
In my package, I tell it I have package “PlexMediaServer”.
It creates:
  1. Service definition
  2. System Internal User entry.
  3. Entire structure under /var/packages
  4. Grants access to the hardware for transcoding.
Clearly DSM 7 fouled up here but I’ve no clue as to how/why.
This is VERY disturbing.
Did you join the DSM 7 beta early back when it started ?
No, never used any DSM 7 beta. I waited for the oficial final release and also had the latest of everything, including the last DSM6 Plex package installed before doing any upgrade.
Indeed something with the DSM upgrade that failed, that’s my feeling. My DHCP server package was also not working, the same type of issue around permissions. Only fixed with reset and re-install DSM.
Anyone else having issues with the last files you added not being picked up in a library scan? Is there a way to clean scan the whole drive?
@plex_paulhilder_com
Control Panel - Shared Folders - EDIT the shared folder - Permissions tab - System Internal User (dropdown) - PlexMediaServer
If the issue is not being able to automatically detect new files, that’s not DSM 6 or 7 related. That’s the Linux kernel table.
Please share whether this is the automatic or general scanning issue ?
That is unfortunate.
Did you make a backup of your DSM settings prior to resetting / reinstalling DSM ?
I am glad everything else is now working for you. This is/was such an ordeal.
So the steps i took. Yesterday i’d copied over some new music into my Synology music folder, but I didn’t get around to doing a rescan in Plex via the scan library option.
Today i’ve followed the steps to install DSM 7, including the updating permissions etc and then installing newer Plex. So far so good.
I can see all the music etc that had been scanned previously, but not the new files I copied over yesterday. Wondering if I was to delete and re copy them over and then scan it would pick them up?
Paul,
Are you expecting PMS to automatically detect the new files ?
So that I’m clear, what was the result of manually scanning ?
If automatic detection has ceased working, the most common cause is filling up the default notification table linux provides – which is easily increased.
Yeah normally when i copy new music to my drive and the rescan it picks them up fine. How would I increase the linux table?
Ok so I guess my question should have been, we need to do the uninstall, upgrade to DSM7, install Plex for DSM7 process. There is no way to just update to DSM7 and update with Plex for DSM 7 without hitting the permission problems etc?
Will that be sorted at some point or the manual intervention will be needed?
Tnx again.
You need to make sure to get an accurate directory count then round up to the next integral 32768 boundary (keeps memory aligned nicely without waste)
This works for 7 too.
I’m seeing a lot of stuff flying about in here. I’m trying to distill that stuff down to some high level prep and implementation steps presuming the user has a properly functional PMS on DSM 6.x.
Prep:
  1. Download DSM 7
  2. Download the Latest PMS for DSM 7
  3. Do we need to adjust permissions or create the Plex MediaServer user?
  4. Backup?
Implement
  1. Remove PMS from DSM 6.x
  2. Install DSM 7 and reboot
  3. Install PMS for DSM 7
  4. Run migration once and follow instructions closely
Yay?
@Sagiplex
NO.
  1. Uninstall the DSM 6 Plex app
  2. Now do the DSM 7 upgrade
  3. Restart DSM 7 again after it finishes
  4. Now you can download the DSM 7 app
  5. Follow the instructions it gives in the popups (failure messages)
  6. These messages tell you what’s missing / remaining to do
  7. When all requirements are satisfied, it will sit there in “Installing” .. and spin.
  8. This is normal and takes time – depends on how many media files you have indexed.
I’ve documented it here: First part is what changed. Second part (post #6) shows what to do.
Also previously repeated in this thread:
https://forums.plex.tv/t/synology-dsm-7-release-plex-installation-issues/719845/465
Here is another view of the instructions:
https://forums.plex.tv/t/synology-dsm-7-release-plex-installation-issues/719845/596
Did it and got the follow error (pic and logs attached).
Migration.log (1.0 KB)
I fixed permissions and started Plex. It seems to be fine. Didn’t have to reinstall and won’t unless you (@ChuckPa) say it’s needed.
