Plex Media Server - Synology DSM 7 Preview - Issues ( Archive )
I assume you mean?
New PLex
Sorry I missed that. Still waking up a bit here .
Let me summarize? Please confirm each point
  1. You have a completely new installation of PMS on DSM 7 after having erased your previous metadata ( it was salvageable but I did need sleep :wink: )
  2. ā€œNot Authorizedā€ whenever you attempt to open http://ip.addr.of.syno:32400/web
To get your server back, (Fix the ā€œnot authorizedā€), we simply need to bring it back into your account.
  1. Make sure you are signed into Plex.tv
  2. Open https://app.plex.tv
  3. Settings - Authorized Devices - Server (dropdown)
  4. Look for your server name
  5. REMOVE the older entries for it. We only want this current one
  6. Come back to the syno
  7. Package Center
  8. Uninstall the DSM 7 app with the KEEP option
  9. Reinstall the package – ā€œPlex Claim Tokenā€ option.
  10. Click ā€œGet Claim Tokenā€, copy the token, paste back into the installer window
  11. Click Install.
  12. Allow the installer to communicate with Plex.tv on your behalf (15-20 seconds)
  13. It will complete the package installation
  14. It will respond (with a popup) saying installation is complete and was Claimed to your Plex username
@gporter416
Those look like it :slight_smile:
@ChuckPa
  1. yes, you’re right :grinning: … but I understand, sleep is very important!
  2. actually it suppose that here was the problem when I’ve tried to setup my server (not authorized issue) from program list app… I have opened app from program list in my syno and it was referred to other address than:
it was actually (see attached screenshots):
https://***.direct.quickconnect.to:32400/web
and this has caused probably the error message. When I wrote in browser http://ip.addr.of.syno:32400/web process of initial setup started immediately and my syno shows as server in my plex account…
Thanks again for your help!
@Emillian
Are you all ok now?
Using a Quick Connect or other remote loop-through address does not work with PMS because it sees that loop-through as a WAN (public) IP. PMS cannot be claimed from a public IP (default security to protect your server from being claimed by someone you don’t know)
This is another reason I added the ā€œPlex Claim Tokenā€ installation method.
It will work through the remote connection.
@ChuckPa
Yes, thank you! :wink: Now it will take a little time to update the library as it was before… but what to say, next time I will check before any major update to DSM what is the situation with PMS… :blush:. Have a nice day!
PS. can it be changed this in app after installation, to refer to local address instead of QuickConnect link?
Thanks. Plan is to update to this one PlexMediaServer-1.24.0.4897-411e7667f-x86_64_DSM7.spk
I can stop plex first.
@Emillian
I will research changing the address but in the past, DSM controlled it.
I think you’re stuck using the address they list.
If you disconnect from their DDNS, you will most likely get the IP address again.
I just keep a normal http://ip.addr.of.syno:32400/web bookmark in my browser toolbar and forget it.
Once we are up and running fine with plex and DSM 7, can we do updates as normal? I noticed a server update:
ā€œYou are currently running version 1.23.4.4805 on the server ā€œMediaā€. Version 1.23.6.4881 is now available.ā€
Am I good to just download, stop plex, install the update, and carry on?
@air360
If you downloaded from https://plex.tv/downloads, you’re ok to update from there.
Please don’t use Package Center. It is OLD and far out of date
HOWEVER
If you loaded my Forum Preview ā€œ2.0ā€ then don’t update from Plex.tv yet.
My Preview is not part of the normal release software yet. (it will be production status as soon as QA approves it)
My current installed version is: 1.23.4.4805
It downloaded file via the plex web interface: PlexMediaServer-1.23.6.4881-e2e58f321-x86_64_DSM7
The website lists: PlexMediaServer-1.24.0.4897-411e7667f-x86_64_DSM7
Should I wait or update to the one from the website??
Hello,
First, thank you to the team for the help you have provided everyone in this thread. I believe i have a permissions error hidden somewhere thats not visible via the UI.
1.) When I first attempted to follow the instructions and re-install plex, I was never prompted the migration phase. A migration log was never created. Plex showed on the machine but was not able to run. When choosing to run, it would attempt to start but immediately ā€œcrashā€ stating manually stopped.
2.) I found what I hoped to be a solution for this in the thread. A response made to my4000, Synology - DSM 7 Release - Plex Installation Issues - #1019 by ChuckPa — I ran this script as advised.
3.) After the script I attempted to re-install Plex, this time it seemed Migration.log (269 Bytes)
to take… However, after about 15 minutes the migration/installation crashed. The NAS flipped out and changed the hard drive volumes into a read-only state. (I am able to correct this back to read/write only after restarting the NAS.)
4.) Since the last time it failed, installation does not reproduce the migration process. It goes on the system and gives me the same issue I have in 1.) where it does not start up. No additional error message.
I still retain the original Plex folder as well as the User, with my preferences and metadata.
(Logs are going to take a minute to extract)
@Keeg1009
  1. You cannot take commands I’ve given for one user and blindly apply to yourself.
  2. reviewing now
@Keeg1009
  1. Your migration log shows it was starting the processing.
  2. It had not started the final step of actually moving the files.
  3. You are safe to:
  • Uninstall & Erase the DSM 7 package if still there
  • Install again
Concerned about the NAS flipping out.
  1. HDD failure?
  2. Dust bunny / fans ?
Hello,
Thanks for the quick reply. I just want to confirm on the uninstall & erase, whether I’m choosing the #1 normal uninstall, or option #3 uninstall all files. I’ve noticed Uninstall & Erase tossed around in a few sections under different circumstances and just want to confirm I have the correct option.
On the volume, this only occurred after going to 7.0. I got hit with the worst of luck on the upgrade. I was only able to replicate the issue when in the migration process for Plex, or attempting to backup copy the Plex folder.
In my experience, Synology NAS units aren’t ā€œBad Luckā€ happening.
They are very stable electronics.
Most common reasons for DSM to go ā€œwonkyā€.
  1. HDDs are failing because they aren’t ā€œNAS drivesā€
  2. Overheating because it’s never been cleaned.
DSM 7 migration will put a sustained load on the HDDs and CPU. If something isn’t up to specs, this will show it.
Look in your DSM Log and see what the root cause was.
AFTER we know the root cause, THEN we can move forward but NOT until.
@trumpy81 @ChuckPa
One last question.
From main downloads page versus Forum 2.0 there are 2 files. Just want to make sure I’m clear on right DSM 7 one
PlexMediaServer-1.23.6.4881-e2e58f321-x86_64_DSM7.spk
If you want to participate (early release) of the new package,
Then use my package – but you will need wait for me to make new packages
If you want to stay mainstream – that’s ok too.
@trumpy81 @ChuckPa
Thanks again for all your help!.
Chuck is was more in reference to your previous post to me, so based on where I was I’m choosing right
@gporter416
Now I understand why you are having so many problems.
  1. You have the package center BETA package. — YUCK —
  2. Packaging itself is full ā€œproductionā€ status now
  3. Take my Forum Preview package
  4. Perform a NORMAL update (Manual Install)
  5. It will do the rest
3744 was what we used as DSM 7 was being developed – 7.0-41222
@gporter416
You can choose either. Both will serve you.
The Plex.tv/downloads package version is Production status
My Forum Preview is ā€œDeveloper final statusā€. It is not backward compatible with Production . It will restructure your data into the new layout.
In a week or two, it WILL be production.
