Plex remote access issues - cannot connect securely
Confirming the reset corrected the issue.. Plex connecting remotely again. Thx
Am I affected?
No, this affects only servers which are at least 3 months old.
Good evening
Could my server be looked at too please. I may have requested mine a few times whilst setting up a new NAS
This affects only servers which are at least 3 months old.
Thank you I’ll open up a new topic then
I’m having a similar issue @OttoKerner
[mod edit: no, you are not affected by the stuck cert issue]
I think I am having the exact same issue too…
What I see in the logs is the following:
CERT: incomplete TLS handshake from [::ffff:192.168.1.20]:55626: sslv3 alert certificate unknown (SSL routines)
Hello, does my certificate need reset?
Thank you for your efforts. The remote access problem I was having has been resolved after the restart.
I am suddenly not able to access my servers outside of my network with the “Not available outside your network”. No changes have taken place. I have restarted and still have the issue. @OttoKerner do you have any insight?
Update: the settings on app.plex.tv on my local network now say “Fully accessible outside your network”, yet any attempt at connecting from out of the network shows “Server is offline”
[mod edit: you are not affected by the stuck cert issue. please open your own forum thread.]
I, too, have an issue with remote access. internal works fine. No changes have been made to my server.
CERT: Error acquiring new certificate: Failed to upload CSR: 429,
SSL peer certificate or SSH remote key was not OK) (SSL certificate problem: certificate has expired)
Thanks Otto!
I figured out my issue, it was DNS.
Apparently using the DNS4EU in my PiHole blocked any local plex web app from accessing my server. Changing it to Google and Cloudflare DNS fixed it.
Hi @OttoKerner, i believe i may be affected as well, are you able to check my certificate please?
Thank you in advance
I have reset the certs of all affected users in this thread so far.
Please stop and restart your servers.
Please refer to your original post above for a moderator edit. If you are not affected by this particular issue, I have added a note in there.
Maybe take a look at Important note about Chrome and Firefox Local Network Access
and do also compare the hosted web app with the local web app.
Ensure that you are not on an old server version between 1.41.7.x to 1.42.0.x
If there are still issues, please open your own forum thread.
I am having this same issue and have already restarted my server multiple times but it did not help. Are you manually revoking bad certs?
Restarting is not much use without someone revoking the stuck cert on plex.tv
Which I have done now. Please stop and restart the affected server once more.
Yep, that resolved it. Greatly appreciated.
I am having the same problem
[mod edit: you are not affected by the stuck cert issue]
can you check if I have a stuck certificate problem? I verified server mapping - public port can be accessed, local port works as expected etc. and I’ve been stumped for the past few hours until I saw this thread
