Plex remote access issues - cannot connect securely
I think I have the same issue, please check :slight_smile:
br
Done. Please stop and restart your server.
@DaTorkar and @kaspers You are not affected by the “stuck cert” issue.
Maybe take a look at Important note about Chrome and Firefox Local Network Access
and do also compare the hosted web app with the local web app.
If there are still issues, please open your own forum thread.
I think I have the same issue, could you check please?
tanks
Please wait at least 10 minutes, then stop and restart your server.
I have the same issue, however i bought the for life package 4 years ago, and im also having the very same issue where i have my Pc in another room running separate rooter and i have it connected to another it connected to another rooter to extend the internet across the house, i usally watch my plex account on my Playstation 5 sitting in another room, but ive have battled with plex yesterday which is currenlty available and i did was uninstall the app and ive also reinstalled the server as well but im having the very same issue
[mod edit: you are not affected by a stuck cert. Please open your own forum thread.]
I am having the same issue. Can you check it?
Ok, for Me it looked like the same issue. :slight_smile:
Made this thread : Lost access to plex server libs and no remote access
br
Hello, could you please also check mine? Thx!
Can you reset mine too please? It’s showing my server cert expired a few days ago and I’ve been racking my brain for hours until I came across this thread.
Can you check mine please? Having same or similar issue
Hi there, I had this begin occurring 4 days ago, remote access stopped working. I’ve tried to confirm it’s the same issue and do seem to see the relevant certificate errors in the logs. Thank you.
I believe I am also affected.
Logs show:
Nov 21, 2025 06:25:11.941 [137640554343056] WARN - [CERT/OCSP] getCertInfo failed; skipping stapling
Is my server/account affected by this issue @OttoKerner ?
same issue here. is my account effected?
I have reset the certs of all affected users in this thread so far.
Please stop and restart your servers.
Please refer to your original post above for a moderator edit. If you are not affected by this particular issue, I have added a note in there.
Thanks, mine working now :slight_smile:
I have the same problem. Thanks for your help!
You are not affected by a stuck cert. Please open your own forum thread.
Can you check mine please, I’ve tried several adding ports and changing the manual port and it changes to fully accessible and after a minute goes back to not avalible.
