PS5 App will not connect to Local Servers
Server Version#: 1.20.5.3562, 1.20.5.3583
Player Version#: 5.4.1
Platform Version#: 2.20
System Software: 20.02-2.25.00.02-00.00.00.0.1
Playstation 5 player simply will not connect to a local server. Reports “[xxx] is Currently Unvailable / Please verify that the server is running and has a network connection” …
PS5 is on the same switch (not router/firewall) as the plex server, and the same /23 subnet.
Playstation 4 player on the same switch unaffected.
Another person in r/plex was also reporting this issue. I believe it is a client issue (because I can’t even see the packets coming at the server ;o). Unfortunately my switch is dumb so I can only check this from the PC side.
I can however, play plex tv content (eg live TV).
Can confirm: Plex app on PS5 is unable to see my server, whether by logging in or entering its address in the “manual server” settings. Plex app on PS4 works fine on the same network.
What is the secure connection setting set to on your server and what is the “allow insecure…” set to in the Playstation app
Can also confirm. having the same exact issue. i was the one that originally posted on reddit and only got a real reply from elshandra. the rest were snarky salt cuz i got a PS5. people sometimes…i swear. i just asked a simple question…lol.
in my case, my Plex server has Secure Connections = Disabled. PS5 is just default settings which i believe allows insecure connections.
Initially, my settings were:
Server: Secure Connections: Preferred
Client: Default
I have also tried:
Client:
Allow Insecure Connections: On same Network;
Prefer Insecure Connections: On same Network;
Client:
Allow Insecure Connections: Never
Prefer Insecure Connections: Never
Server: Secure Connections: Required
Client:
No matter what I do with the client settings, it is not sending any traffic to my sever (I’ve been running wireshark). I can see the broadcast traffic from the PS5, if I ping the PS5, I can see the echo requests and replies. But whatever I do in plex, results in network silence.
e: FWIW, I also tried turning logging on … hoping that maybe the logging engine would at least send me some data, but nope still silence.
I also can’t connect locally. Interestingly, of the two remote servers I’m shared, one works and the other has the same error as local. I do not know what the difference between those remote servers is, but it’s hopeful that one works.
Hey all. Sorry for the inconvenience. I’m looking into the issue with Sony, and to see if there are any console settings that may affect behaviour.
Mine didn’t want to initially connect to Plex. But after restarting the server and updating in the PS5 it works fine. But live TV doesn’t directly for some reason. It just sits at buffering unless you drop the amount down so it can trans code
I wonder if the issue is Windows 10. Did you do the new update on Windows 10? I’ve been having issues since then in terms of live TV staying in sync and server visibility.
My servers are solid for all other uses (Android, PS4, Web). I did do the update to Windows 10, and I don’t run any firewall/network/virus protection (other than Defender.)
Also, there is no traffic coming to the server. Until there is traffic coming to the server, it is probably irrelevant.
I am curious as to what version of System Software you have on your PS5 though, if it is working for you to a local server.
I’m glad its not just me having this issue. Tried Uninstaller plex and re linking. Tried updating and restarting the server. Tried manual connection. Haven’t tried port fwding bc I don’t know which ports to open for ps5. Guess the pro will be used for plex for now
Same issue here, client from the PS5 can’t connect to the local server (port 32400), tried the manual connection secure and insecure, same issue.
Plex Server 1.20.4.2517
PS5
Client Version 5.4.2
Platform 2.20
Please guys work with Sony for a Solution.
Just adding to the count, new PS5 users - same settings/version’s as above and PS5 unable to see/connect to the server (thinks it’s offline/unreachable). PS4/TV app connect fine as usual.
Another here with the same issue. PS4 Pro is working fine. I spent a couple of hours messing with this trying to match all the settings in the PS5 app etc before finding this thread.
Same here, works on all devices but PS5, have messed around for ages and still no joy.
I just want to add to the count as well; I can’t connect to my server. FWIW I use Ubuntu, not Windows, and the app works fine on my AppleTV but can’t get a server connection on PS5. PS5 is my first game console so I can’t weigh in on it working on prior consoles. Currently on my PS5 the live TV function works without issue.
I would really like to stream music via DLNA in the background while playing games.
Add another one to the list here. No local servers on PS5
My mates cloud server works perfectly and connects fine. purely just local server.
Windows 10 home
10.0.19041 Build 19041
PMS: 1.20.4.3517
Having the exact same issue.
The Plex app on PS5 sees remote servers but not local ones.
The app works fine on my PS4, Roku TV, iPad, Android… just not PS5
