Server Version#:PlexMediaServer_1.14.0.5468-5a0183d2c_x86_64
Player Version#:Latest (not getting that far)
So all was working fine. Decided to do an update and downloaded the qpkg.
Updated, PMS not showing up.
Re-installed, still not good.
Following some trouble shooting around removed prefs files from
/share/CACHDEV1_DATA/.qpkg/PMS
In the end, went with removing it and going back to the one from the QMS app store.
Still no joy.
Went back to latest version from PLEX
Installed OK, but
Server settings are unavailable.
Plex says server available to be claimed but then logs me back in.
Tried the previous couple of qpkgs, I’ve used, no joy.
Trying to sign in to plex and claim it that way gives me a
404 Not Found
Help?
ChuckPa
2
What previous version of PMS do you have on hand?
whichever lower version is it (within reason), Install it on top of the existing.
QTS manual install always uses CACHEDEV1_DATA so you are good.
Be advised, under .qpkg the name is PlexMediaServer not PMS verbatim.
The best next action is:
- Stop PMS
- Install PMSLibShare if you don’t have it
See Dane22 post below for link
- Open it in File Station and dril into the Plex share
- In it, under Library, you will see Preferences.xml
- Rename it to Preferences.xml.old or delete it (your choice)
- Restart PMS
- Open an in-cognito window to your QNAP
- Begin the setup again EXCEPT do not create library sections… They already exist.
- Skip through to the Dashboard (Finish)
- report progress please
Ok Step one done.
Mod: Link removed
What does PMSlibshare do please.
how do I open it in file station?
I install via the app centre local in install and it installs but doesn’t appear to open.
PS went with
PlexMediaServer_1.11.0.4633-70f9c31ed_x86_64
I also have
PlexMediaServer_1.13.6.5339-115f087d6_x86_64
dane22
5
PMSLibShare: Create a share for Plex Library Directory
And please use the link from that post!
ChuckPa
6
Dane22 is the author of PMSLibShare.
I have the qpkg handy on my google drive as well. (we use it that frequently)
Ok Qnap updated the PMS to 1.13.5.291
This is done. However I still see no share in File Manager?
dane22
9
Should show up as a share named Plex ?
dane22
10
And are you logged on as admin?
Not on file manager, in qnap cloud is does, but says is empty and I get an error
The destination file or folder does not exist on the device. 1129104
and yes, logged on as admin
dane22
12
Strange, and never seen that before.
If possible, try and reboot your QNAP
Ok really strange thing is the PMS appears to have started properly after uninstalling pms share and rebooting.
I’ll stop PMS and install PMS share again
Ok steps I’m doing.
Stop PMS
uninstall pms-share.
Re-install from your link.
open pms-share.
start pms
No plex share.
About to reboot.
Gah, now I’ve got a firmware update.
Be right back…
3 reboots later. Still no plex share.
Ok, so PMS now working, but I now have
The dashboard is empty
Add libraries with your media to make the most of Plex Media Server
ChuckPa
18
Had you previously relocated PMS to a different volume?
ChuckPa
19
FYI. Operations is having an issue. Your data might be there just invisible.
Please stand by.
