Good morning. Since a few weeks I can’t find the Server library from the external devices I was using (it shows in red that it’s offline). In addition, from time to time, a warning symbol appears from the server indicating an error and referring me to the forums (that’s how I found this thread). Could you give me some help, please. Thanks in advance.
Good afternoon @ChuckPa. I understand that you mean the start of the library server name. It would be: 1.Cas… If it is seen, it is from the PC itself where PMS is installed. From an Android phone and Ipad the library is not displayed The second library server is completely unknown to me. I’m not in Germany.
at first i though it was fritz modem since it had an update last month but today when i removed /re-added all ports and was still locked i though to check eset firewall options
I resolved the question/confusion with the other server. At one time , you had a different name. That’s the one I saw. I know , by looking at your plex account, where you’re at
The PC server is the being seen so if all is good now then
From your logs, I don’t see where the server was ever claimed.
It looks like the server was started, and before it could complete setup, it was reinstalled again. (I should have seen evidence of claiming in the logs)
Are you having trouble claiming the server / keeping it claimed ?
This is useful:
NAT: PMP::getPublicIP, couldn’t initialize: -3:Unable to get Gateway
Is the Shield’s network configuration pointing to your network modem/router correctly ?
