Task: plex test
Start time: Wed, 17 Nov 2021 18:08:43 GMT
Stop time: Wed, 17 Nov 2021 18:08:43 GMT
Current status: 0 (Normal)
Standard output/error:
Plex is located at “/volume*/[Pp][Ll][Ee][Xx]"
DSM 6 installation found at "/volume/[Pp][Ll][Ee][Xx]/Library/Application Support/*”
#!/bin/bash
echo Plex is located at /volume*/[Pp][Ll][Ee][Xx]*
echo DSM 6 installation found at: /volume*/[Pp][Ll][Ee][Xx]/Library/Application\ Support/*
The output should be similar:
chuck@ds418:~$ ./findplex
Plex is located at /volume1/Plex /volume1/PlexMediaServer
DSM 6 installation found at: /volume1/Plex/Library/Application Support/Plex Media Server
chuck@ds418:~$
When this runs, I really expect to find duplication somewhere.
DSM 6 installation found at: /volume*/[Pp][Ll][Ee][Xx]/Library/Application Support/*
It does feel like that. Doing my head in.
I had followed your guides in upgrading to DSM7 exactly. Only steps I potentially missed were adding admin rights to the DSM7 PlexMediaServer user, but did add read/write.
The Library Bsckup folder was created at some point during the update attempts. I copied the Application support folder out as an attempt to fix
edit just seen the missing “library” folder. trying again with script with that created.
added the Library folder in appropriate place
Going to retry migration now that seems more resolved. Removing current DSM7 plex install entirely, leaving permissions and reinstalling
I got everything set back up and running a Data Scrubbing operation on my storage. When I tried to run the manual install on Plex, it definitely moved past the earlier error. But, I got to a question about Installation Type, Normal or Install using Plex Claim Token. Wasn’t sure about which way to go.
If PMS was running normally (signed in and all status OK) then you can give “normal” a try.
“Normal” will leave all the existing account credentials as they are. It will just install software.
“Plex Claim token” goes the extra step. It installs the software PLUS it overwrites any existing credentials (with the credentials from the Claim Token).
I just realized that I should have backed up my Surveillance Station config. I’m guessing that wasn’t in the CP backup I did since I now have nothing after installation.
Ok, this is puzzling…before I fixed the permissions, I could sign into PMS but didn’t see any media. Now, I can’t sign in. I get an error screen saying “Not authorized You do not have access to this server.” Any thoughts?
What’s strange, is that I can’t sign in using my administrative user but I can using a managed user. When I sign onto the managed user, it comes up and says “No content available.” Could this be related to the name of the Synology being changed? I couldn’t remember exactly what I had named it previously so I’m thinking the name may be slightly different than before. When I try to click on one of the media folders, I get a message stating that “old name” is currently unavailable. Of course, this still doesn’t explain why I can’t log into the server using my administrative user.
