Synology NAS - $NAME is currently unavailable
Server Version#: 1.18.4.2171
Player Version#:7.25.2.14287
Everyday when I attempt to access local content on my synology NAS hosted plex, I get error:
Error: $NAS_NAME is currently unavailable
“Please verify the server is running and has a network connection”
The directories in which plex has been configured all have yellow triangle exclamation marks on them on the left hand pane, and does not load any content. The content properly works with mobile apps (checked and verified with android and ipad apps), and works with web browsers just fine.The issue is that both of my amazon fire devices present the same issue of not properly loading the content.
If I uninstall or reinstall the app from amazon fire tv, Plex loads and works just fine. Its until I shutdown the NAS or reboot that it will not properly work or load anymore (in this case my NAS powers down daily).
I thought it had to deal with a recent permissions change I noticed in the forusm, so I gave the user plex admin rights to all content just as a sanity check, but still have the same errors.
Log files please,
FAQ #1 (post 2) if you need to.
It’s not clear if this is a problem with the Amazon or the Synology or the networking between them
Jan 10, 2020 15:30:43.048 [0x7f470e88f700] DEBUG - Content-Length is -1 (of total: -1).
Jan 10, 2020 15:30:44.056 [0x7f4766b2e700] DEBUG - Request: [XXX.XXX.XXX.XXX:15095 (Subnet)] OPTIONS /:/prefs?LogVerbose=1 (8 live) TLS GZIP Signed-in Token ()
Jan 10, 2020 15:30:44.056 [0x7f4789f1a700] DEBUG - Completed: [XXX.XXX.XXX.XXX:15095] 200 OPTIONS /:/prefs?LogVerbose=1 (8 live) TLS GZIP 0ms 301 bytes
Jan 10, 2020 15:30:44.057 [0x7f4789f1a700] DEBUG - Auth: authenticated user 1 as user
Jan 10, 2020 15:30:44.058 [0x7f470e88f700] DEBUG - Request: [XXX.XXX.X.XXX:15094 (Subnet)] PUT /:/prefs?LogVerbose=1 (8 live) TLS GZIP Signed-in Token (user)
Jan 10, 2020 15:30:44.059 [0x7f4789f1a700] DEBUG - Completed: [XXX.XXX.XXX.XXX:15094] 200 PUT /:/prefs?LogVerbose=1 (8 live) TLS GZIP 1ms 274 bytes (pipelined: 4)
Jan 10, 2020 15:30:44.830 [0x7f4789c2c700] VERBOSE - WebSocket: processed 1 frame(s)
Jan 10, 2020 15:30:51.405 [0x7f4789f1a700] VERBOSE - WebSocket: processed 1 frame(s)
Jan 10, 2020 15:30:52.171 [0x7f4789f1a700] VERBOSE - WebSocket: processed 1 frame(s)
Jan 10, 2020 15:30:53.753 [0x7f4789f1a700] VERBOSE - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Jan 10, 2020 15:30:53.753 [0x7f4789f1a700] DEBUG - Auth: authenticated user 1 as user
Jan 10, 2020 15:30:53.753 [0x7f4789f1a700] VERBOSE - Auth: Came in with a super-token, authorization succeeded.
Jan 10, 2020 15:30:53.754 [0x7f4764af4700] DEBUG - Request: [YYY.YYY.YYY.YYY:33420 (Subnet)] GET / (7 live) TLS GZIP Signed-in Token (user)
Jan 10, 2020 15:30:53.754 [0x7f4764af4700] VERBOSE - * X-Plex-Version => 7.25.2.14287
Jan 10, 2020 15:30:53.754 [0x7f4764af4700] VERBOSE - * X-Plex-Client-Identifier => e35ad71f49325863-com-plexapp-android
Jan 10, 2020 15:30:53.754 [0x7f4764af4700] VERBOSE - * X-Plex-Device-Name => AFTT
Jan 10, 2020 15:30:53.754 [0x7f4764af4700] VERBOSE - * X-Plex-Platform => Android
Jan 10, 2020 15:30:53.754 [0x7f4764af4700] VERBOSE - * X-Plex-Platform-Version => 5.1.1
Jan 10, 2020 15:30:53.754 [0x7f4764af4700] VERBOSE - * X-Plex-Provides => player,pubsub-player,controller
Jan 10, 2020 15:30:53.754 [0x7f4764af4700] VERBOSE - * X-Plex-Product => Plex for Android (TV)
Jan 10, 2020 15:30:53.754 [0x7f4764af4700] VERBOSE - * X-Plex-Device => AFTT
Jan 10, 2020 15:30:53.754 [0x7f4764af4700] VERBOSE - * X-Plex-Model => tank
Jan 10, 2020 15:30:53.754 [0x7f4764af4700] VERBOSE - * X-Plex-Device-Vendor => Amazon
Jan 10, 2020 15:30:53.754 [0x7f4764af4700] VERBOSE - * X-Plex-Device-Screen-Resolution => 1920x1080 (Android TV)
Jan 10, 2020 15:30:53.754 [0x7f4764af4700] VERBOSE - * X-Plex-Device-Screen-Density => 320
Jan 10, 2020 15:30:53.754 [0x7f4764af4700] VERBOSE - * X-Plex-DRM => widevine:video
Jan 10, 2020 15:30:53.754 [0x7f4764af4700] VERBOSE - * X-Plex-Advertising-Identifier => 4f6f04ff-1c63-49c8-9a04-11814e02d6b8
Jan 10, 2020 15:30:53.754 [0x7f4764af4700] VERBOSE - * X-Plex-Advertising-DoNotTrack => 1
Jan 10, 2020 15:30:53.754 [0x7f4764af4700] VERBOSE - * X-Plex-Username => user
Jan 10, 2020 15:30:53.754 [0x7f4764af4700] VERBOSE - * Accept-Language => en-us
Jan 10, 2020 15:30:53.754 [0x7f4764af4700] VERBOSE - * Accept => application/xml
Jan 10, 2020 15:30:53.754 [0x7f4764af4700] VERBOSE - * User-Agent => Dalvik/2.1.0 (Linux; U; Android 5.1.1; AFTT Build/LVY48F)
Jan 10, 2020 15:30:53.754 [0x7f4764af4700] VERBOSE - * Host => ZZZ.ZZZ.ZZZ.ZZZ:32400
Jan 10, 2020 15:30:53.754 [0x7f4764af4700] VERBOSE - * Connection => Keep-Alive
Jan 10, 2020 15:30:53.754 [0x7f4764af4700] VERBOSE - * Accept-Encoding => gzip
Jan 10, 2020 15:30:53.754 [0x7f4764af4700] VERBOSE - * X-Plex-Token => xxxxxxxxxxxxxxxxxxxx
Jan 10, 2020 15:30:53.755 [0x7f4764af4700] DEBUG - (Capabilities) Platform ‘Android’ not matched by plugin platform requirements
Jan 10, 2020 15:30:53.755 [0x7f4764af4700] VERBOSE - It took 0.0 sec to serialize a list with 24 elements.
Jan 10, 2020 15:30:53.756 [0x7f4789f1a700] DEBUG - Completed: [YYY.YYY.YYY.YYY:33420] 200 GET / (7 live) TLS GZIP 2ms 2314 bytes (pipelined: 1)
Jan 10, 2020 15:30:53.809 [0x7f4789c2c700] DEBUG - WebSocket: client initiated close
Jan 10, 2020 15:30:53.809 [0x7f4789c2c700] VERBOSE - WebSocket: processed 0 frame(s)
Jan 10, 2020 15:30:53.810 [0x7f4789c2c700] DEBUG - NotificationStream: Removing because of close
Jan 10, 2020 15:30:53.856 [0x7f4789f1a700] DEBUG - handleStreamRead code 2: End of file
Jan 10, 2020 15:30:53.856 [0x7f4789f1a700] DEBUG - Completed after connection close: [YYY.YYY.YYY.YYY:43365] -3 GET /:/websockets/notifications (7 live) TLS GZIP 391694ms 1075 bytes
Jan 10, 2020 15:30:53.930 [0x7f4789c2c700] VERBOSE - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Jan 10, 2020 15:30:53.930 [0x7f4789c2c700] DEBUG - Auth: authenticated user 1 as user
Jan 10, 2020 15:30:53.930 [0x7f4789c2c700] VERBOSE - Auth: Came in with a super-token, authorization succeeded.
Jan 10, 2020 15:30:53.930 [0x7f470e88f700] DEBUG - Request: [YYY.YYY.YYY.YYY:38555 (Subnet)] GET /:/websockets/notifications (7 live) TLS GZIP Signed-in Token (user)
Jan 10, 2020 15:30:53.930 [0x7f470e88f700] VERBOSE - * Upgrade => websocket
Jan 10, 2020 15:30:53.930 [0x7f470e88f700] VERBOSE - * Connection => Upgrade
Jan 10, 2020 15:30:53.930 [0x7f470e88f700] VERBOSE - * Sec-WebSocket-Key => WnJR3GDLHzlTiW8sOB2Wrw==
Jan 10, 2020 15:30:53.930 [0x7f470e88f700] VERBOSE - * Sec-WebSocket-Version => 13
Jan 10, 2020 15:30:53.930 [0x7f470e88f700] VERBOSE - * Host => ZZZ.ZZZ.ZZZ.ZZZ:32400
Jan 10, 2020 15:30:53.930 [0x7f470e88f700] VERBOSE - * Accept-Encoding => gzip
Jan 10, 2020 15:30:53.931 [0x7f470e88f700] VERBOSE - * User-Agent => okhttp/2.6.0
Jan 10, 2020 15:30:53.931 [0x7f470e88f700] VERBOSE - * X-Plex-Token => xxxxxxxxxxxxxxxxxxxx
Jan 10, 2020 15:30:53.931 [0x7f470e88f700] DEBUG - WebSocket: Performing handshake from origin
Jan 10, 2020 15:30:53.931 [0x7f470e88f700] DEBUG - Beginning read from WebSocket
Jan 10, 2020 15:30:54.831 [0x7f4789f1a700] VERBOSE - WebSocket: processed 1 frame(s)
Jan 10, 2020 15:30:58.773 [0x7f4789f1a700] VERBOSE - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Jan 10, 2020 15:30:58.773 [0x7f4789f1a700] DEBUG - Auth: authenticated user 1 as user
Jan 10, 2020 15:30:58.773 [0x7f4789f1a700] VERBOSE - Auth: Came in with a super-token, authorization succeeded.
Jan 10, 2020 15:30:58.773 [0x7f4764af4700] DEBUG - Request: [YYY.YYY.YYY.YYY:33420 (Subnet)] GET / (7 live) TLS GZIP Signed-in Token (user)
Jan 10, 2020 15:30:58.774 [0x7f4764af4700] VERBOSE - * X-Plex-Version => 7.25.2.14287
Jan 10, 2020 15:30:58.774 [0x7f4764af4700] VERBOSE - * X-Plex-Client-Identifier => e35ad71f49325863-com-plexapp-android
Jan 10, 2020 15:30:58.774 [0x7f4764af4700] VERBOSE - * X-Plex-Device-Name => AFTT
Jan 10, 2020 15:30:58.774 [0x7f4764af4700] VERBOSE - * X-Plex-Platform => Android
Jan 10, 2020 15:30:58.774 [0x7f4764af4700] VERBOSE - * X-Plex-Platform-Version => 5.1.1
Jan 10, 2020 15:30:58.774 [0x7f4764af4700] VERBOSE - * X-Plex-Provides => player,pubsub-player,controller
Jan 10, 2020 15:30:58.774 [0x7f4764af4700] VERBOSE - * X-Plex-Product => Plex for Android (TV)
Jan 10, 2020 15:30:58.774 [0x7f4764af4700] VERBOSE - * X-Plex-Device => AFTT
Jan 10, 2020 15:30:58.774 [0x7f4764af4700] VERBOSE - * X-Plex-Model => tank
Jan 10, 2020 15:30:58.774 [0x7f4764af4700] VERBOSE - * X-Plex-Device-Vendor => Amazon
Jan 10, 2020 15:30:58.774 [0x7f4764af4700] VERBOSE - * X-Plex-Device-Screen-Resolution => 1920x1080 (Android TV)
Jan 10, 2020 15:30:58.774 [0x7f4764af4700] VERBOSE - * X-Plex-Device-Screen-Density => 320
Jan 10, 2020 15:30:58.774 [0x7f4764af4700] VERBOSE - * X-Plex-DRM => widevine:video
Jan 10, 2020 15:30:58.774 [0x7f4764af4700] VERBOSE - * X-Plex-Advertising-Identifier => 4f6f04ff-1c63-49c8-9a04-11814e02d6b8
Jan 10, 2020 15:30:58.774 [0x7f4764af4700] VERBOSE - * X-Plex-Advertising-DoNotTrack => 1
Jan 10, 2020 15:30:58.774 [0x7f4764af4700] VERBOSE - * X-Plex-Username => user
Jan 10, 2020 15:30:58.774 [0x7f4764af4700] VERBOSE - * Accept-Language => en-us
Jan 10, 2020 15:30:58.774 [0x7f4764af4700] VERBOSE - * Accept => application/xml
Jan 10, 2020 15:30:58.774 [0x7f4764af4700] VERBOSE - * User-Agent => Dalvik/2.1.0 (Linux; U; Android 5.1.1; AFTT Build/LVY48F)
Jan 10, 2020 15:30:58.774 [0x7f4764af4700] VERBOSE - * Host => ZZZ.ZZZ.ZZZ.ZZZ:32400
Jan 10, 2020 15:30:58.774 [0x7f4764af4700] VERBOSE - * Connection => Keep-Alive
Jan 10, 2020 15:30:58.774 [0x7f4764af4700] VERBOSE - * Accept-Encoding => gzip
Jan 10, 2020 15:30:58.774 [0x7f4764af4700] VERBOSE - * X-Plex-Token => xxxxxxxxxxxxxxxxxxxx
Jan 10, 2020 15:30:58.775 [0x7f4764af4700] DEBUG - (Capabilities) Platform ‘Android’ not matched by plugin platform requirements
Jan 10, 2020 15:30:58.775 [0x7f4764af4700] VERBOSE - It took 0.0 sec to serialize a list with 24 elements.
Jan 10, 2020 15:30:58.776 [0x7f4789c2c700] DEBUG - Completed: [YYY.YYY.YYY.YYY:33420] 200 GET / (7 live) TLS GZIP 2ms 2314 bytes (pipelined: 2)
Jan 10, 2020 15:31:01.405 [0x7f4789f1a700] VERBOSE - WebSocket: processed 1 frame(s)
Jan 10, 2020 15:31:03.048 [0x7f4789650700] VERBOSE - LongPoll: Sending data…
Jan 10, 2020 15:31:03.048 [0x7f4789c2c700] VERBOSE - LongPoll: got onDataRequested, closing connection
The ZIP file please. I cannot diagnose anything from a snippet.
ALSO, please turn VERBOSE off. Keep DEBUG on (these are the defaults and are best for initial diagnostic purposes)
