TV Episodes not showing correct title
I am having a problem I just can’t figure out. I am using MakeMKV to rip my Star Trek: Enterprise blu-ray discs on WIndows 10. I then use Handbrake to convert them from 6GB mkv files to about 1.2 GB m4v files. I put them in my Plex media directory as shown below
 /Videos
    /TV Shows
        /Star Trek Enterprise
            /Season 1
                Star Trek Enterprise - s01e01 - Broken Bow.m4v
                Star Trek Enterprise - s01e26 - Shockwave Part 1.m4v
            /Season 2
                Star Trek Enterprise - s02e01 - Shockwave Part 2.m4v
                Star Trek Enterprise - s02e02 - Carbon Creek.m4v
                Star Trek Enterprise - s02e11 - Precious Cargo.m4v
The problem is that for Season 1 all the episode names show up correctly but for Season 2 the first 8 episodes show up as “Star Trek: Enterprise Season 2 Disc 1” (4 episodes) and “Star Trek: Enterprise Season 2 Disc 2” (4 episodes). From Episode 10 on the episode names appear correct.
I have tried the Plex Dance (remove media, scan, optimize database, etc.) but when I put the media back, they still show up that way.
The meta data in the m4v file has the bad name (e.g. “Star Trek: Enterprise Season 2 Disc 1”) but then so do the ones which are showing correctly. I tried editing the Title to be the episode title, but the bad name is still displayed.
Any suggestions?
Remove the metadata from the m4v files, then plex dance. That or change the order of the agents. Make Local media assets at the bottom.
we are still plague with this. It’s so tiresome.
I changed the Title in the m4v file and danced with Plex but the problem persists. I am now even more baffled because I know the “Season 2 Disc 1” string is not in the meta data of the file at all but it still shows up that way. I don’t think I even have Local Media assests enabled for TV Shows:
I beginning to think that TheTVDB is confused but when I look through the web site, it looks correct.
I also am baffled as to why episodes 9-26 display correctly but have the wrong local media title embedded in the m4v.
There could be 2 reasons:
  1. you did not perform all steps of the Plex Dance or in the wrong order
  2. The tv show is not actually matched with the TheTVDB agent. Please post the Plex XML info of one of its episodes to verify this.
Thanks for your help. It seems to be working now. I had to do the Plex Dance twice to get it to work.
I still am curious why some episodes were showing up correctly while others were not even though they all followed the same pattern.
My guess: some had embedded metadata, and some had not.
In the Plex Dance we are asked to “Clean Bundles” … this is the one step that I couldn’t figure out how to do. Am I missing a button/link somewhere in the settings?
Please follow my link how to Plex Dance.
Step 4 is a link which leads you to informations about where to find the command.
“Clean bundles” is in the menu accessed by the three dots next to the word “Libraries” in the main menu. “Empty trash” is available both globally and for individual libraries while “Clean bundles” is global only.
Thanks, Elijah…
