Update and modify collection
hi I have plex 1.28 in my qnap In qts 5.0, I had organized a series and left a season separate from the rest and now I tried to include it along with the other seasons but it doesn’t appear together with the others I tried to exclude the series from the collection to to be able to update and solve the problem but it didn’t work then I tried to do the plex dance but I couldn’t update but there was an error I think can someone give me a tip?
What do you mean?
Also please provide a screen capture from QNAP File station, showing the episodes missing
I left it separate because when I was informed I thought it was a different series with the same characters
this is the way I added the season in the case to 05
example:
< series>
…<season 01>
… <season 02>
… <season 03>
…<season 04>
…<season 05>
…< specials >
< series>
Please provide a screen capture, since we need to see the real naming of the files
Try and name the show folder as:
Ikkitousen (2003) {tmdb-37584}
And I do assume, the your Show Library is pointing towards Animes ?
And lastly, please don’t use the build in Multimedia share!
Ref: Qnap faq.....read me first!
Also sadly can’t see the episodes :wink:
yes that’s right I said series but they are anime in fact, article that you told me how do I find hidden files in the folder and where to star this option plex ignore?
Use an SSH connection, but strongly recommend simply moving your medias away to a regular share
I did as you indicated I created a shared folder and moved the anime there the other information errors were corrected but the fifth season has not yet appeared
Episodes in Season 05 are named as S01
I didn’t really notice that thanks
