DVR | General Feedback & Issues
Hello,
Yeah, looking across multiple sources it seems to be varied which show title they’re using.
https://www.radiotimes.com/tv/tv-listings/?sd=23-12-2019%2021:00
Hopefully you saw this reply :slight_smile: DVR | General Feedback & Issues - #166 by Jakosaur
Also this issue is still occuring for me. Going to grab some new logs and put in that thread :frowning: Server not downloading poster art - #9 by Jakosaur
I did see the first but I have not scheduled time to look into it yet - thanks for the reminder
I had not noticed the other one. I asked for extra info
Had The Royal Insitution Christmas Lectures set to record yesterday (26/12/2019) 8PM 106 BBC4HD. Now gone from the schedule, so no idea if it was unscheduled or there was an error. Only just noticed it didn’t record.
Plex Media Server Logs_2019-12-27_11-29-46.zip (5.2 MB)
I think some Server Notification options to Mobile Apps would be handy. When a show gets scheduled, removed from schedule, channel change for HD/SD (depending on option) & errors when starting to record/during.
DVR Recording - Doctor Who (2005) matched to Doctor Who from 1963 when an exact name match was available.
https://drive.google.com/file/d/11CjPosQwslI140aOpgrRFDMsx5EVlK7w/view?usp=sharing
Logs zip file is empty
Are you using the Enhanced Guide option ?
Oh sorry. Bit odd, I opened the ZIP before I uploaded it :thinking:
I am not.
Some feedback about DVR:
Would be nice to see at a glance which channel(s) are missing/not enabled on certain tuners on the DVR settings page
007-3 should appear as 007 on the guide & when clicked on a scheduled recording, in the schedule view. Just needs to trim - and anything after.
Seasons set to Show in Library Settings.
New DVR Show, no files in library beforehand… once again ignored the library setting. Plex defaults the shows’ Seasons to Hide instead of Library Default.
I waited to grab more logs until a new airing today, but the server is still giving me empty ZIP folders. Server did the exact same thing with Doctor Who again.
I zipped the logs folder as an alternative, hopefully the right thing.
Figured out the empty ZIP folders, was a new permissions error I set on my unRAID server.
Plex Web should show S2020 E1 for Sky at Night in the Now Playing section for your server. As shown on the right, but values changed.
Also would be nice for it to be S3 · E11 - A live Chicken, a ... :slightly_smiling_face:
Some more feedback. In the Recording Priority, can the poster art update if available? Had a show that originally had none, but after clicking a scheduled recording it suddenly had some. Had to cancel the show from recording totally in the priority, and scheduling it again for it to have art in the priority.
Obviously low priority, but some feedback for the future.
When you schedule a recording, for an airing that’s already started; does Plex check if it’s on a HD Channel? Just did a test recording after changing a docker setting, and it used Channel 003 when available in HD on 103. Or does it just go by what channel you scheduled it from if the airing is already in progress? Prefer HD was selected.
Plex Media Server Logs_2020-02-05_10-29-44.zip (4.5 MB)
I believe the preference would only apply to scheduled recordings. I will double check
Could you help me not spend long time to figure out which time the recording you are refer to was. And what time did you add it to the schedule ? Or did you just click on Record from the grid entry?
OK found lots of recordings starting at times between 10:14 and 10:25
So are these pressing record button from grid ?
Correct. Pretending this was the show, I highlighted over it; and pressed the red record button. Then just pressed Record from the Record options screen.
Sorry for so many, was testing something else when I noticed this happening. It was this show.
Yes, from the grid.
Thanks :slightly_smiling_face:
Sorry for bringing this up again as I did mention it a few comments up, but seems to be happening again. New shows (no files exist) for my server from DVR, seem to set Seasons to Hide instead of Library default.
Just noticed this on one of my test recordings I did.
I will raise it for the development team to investigate and address.
I have been ignoring it - or rather postponing when I look into it ! I will find all your posts on this
You’re fine, you’ve been busy on the forums! :blush: Thanks again!
This has now been referred to our development team
