Me TV Toons channels were added to my EPG after a few weeks FWIW. No idea if my request here had anything to do with it though.
Chicago Illinois | MeTV Toons | WCIU 26.7 | Not showing in the EPG drop-down available channel list. I’ve done a refresh of my EPG a few times now with no luck. Can we please get the EPG file updated to reflect this new channel! Thank you.
I’m having same issue:
Jacksonville, FL WJAX MeTV Toons 47.4
Plex doesn’t show channel in EPG drop down list, so it can’t/won’t load channel.
Minnesota and twin cities area is missing channel 5.6 which should be metv toons. Plex shows the channel number but there is no match in the guide.
It feels like Plex is no longer making updates to the guide based on this thread. I have requested updates multiple times and waited months and no update has been made. Is there another way to make this request?
Just sent the following message to Plex billing in hopes someone there will talk to technical support to investigate what is going on in this thread and why no one in the company seems to be working to add channels for customers. I hope someone there responds and actually helps us.
Sent the following message to a thread on the support side that is supposed to be for adding channels to Plex. I sent my particular request on June 22 of this year and the channels have still have not been added. Problem is no one is monitoring the thread anymore since this past spring. I believe the person doing the work left the company (according post made on thread back in April or May). Lots of other people are also sending their missing channel requests to that thread as well and and nothing is being done about it. I know I am directing this message to billing but can someone reach out to support and figure out what is going on since there is no other way for me and others to reach support about this particular issue (adding channels). Here is my request for adding channels from June…
Appleton WI, 54913. Version 4.132.3. I cannot select EPG to match OTA channels in Plex for the following channels. I should be able to add the following channels to the line up.
26.6 QCV
26.7 QVC2
31.1 MeTV
31.2 Toons
31.3 Story
31.4 MeTV+
31.5 MOVIES
49.1 WGBD-LD
49.2 Espanol
Region: Europe
Country: Austria
Postal code: 4020
Lineup: vMVPD - HD Austria
The channel Canal+ First rebranded to Canal+ Action, and the EPG isn’t available (“channel off air”), please kindly update the channel.
What the actual problem : Chaanel KJYY 29.8, MeTV Toons is missing from the line-up, and thus I can’t enable that channel.
Lineup Name: Local Broadcast Listings (95 channels)
Channel number and channel name: MeTV Toons 29.8 KJYY
Your country: United States
Postal Code: 97216
Region/market: Portland
Version of Plex Media Server in use: Version 1.40.4.8679
Freeview Central Scotland EPG missing channels I can get 165 channels (HDhomerun and Plex reporting) EPG is showing only 149 available of which only 136 can be enabled. (some are duplicates or just simply missing channel numbers on EPG.)
Missing Channels and Channel Numbers will be attached as screenshots over 2 posts (limit of 5 uploads) - all unticked channels are not available.
- Country: Scotland, UK
- Postcode: FK2
- Region: Craigkelly Transmitter (Freeview)
- Software Version: BETA: 1.40.5.8796
most of these channels are actually irrelevant to my viewing but would be good to have an up-to-date EPG.
need to post 2 times for attachment limits. apologies.
Part 2 of missing channels on EPG due to duplicates or simply missing - Apologies for double post. Thank you. Antonio.
Thanks for report. It will be passed along to our provider
having and issue with my local broadcast line up.
seems that one broadcaster has moved moved some sub channels around in the market, Susquehanna Valley PA
here is what HD Home run reports which is the correct programs
scripps new has moved to 18.5 and 19.5 It was on x.6 for each broadcast tower but 18.6 & 19.6 are now the Pocono network for which there is no match for in the guide data for me to match to.
The Defy channel has been removed
I am in York Pennsylvaina zip 17404 USA
Using plex server version Version 1.40.4.8679
11 posts were split to a new topic: No EPG for UK
In Australia EPG not loading, auto refresh has stopped. Using manual refresh, it does “Initializing” and then stops.
I reported this issue regarding the DVR confusing 1959 and 2019 versions of The Twilight Zone (starting after the Sky Mix channel staring showing the 2019 version) back in June (and then later as a separate thread).
This is still happening, so I’m having to schedule the 2019 version record and then manually separate the episodes.
Are there any updates on this?
This is my 2nd request for the missing channels I have. Is anyone working on this anymore?
What the actual problem is: Missing guide for two channels.
Lineup Name: Local Broadcast Listings (107 channels)
Channel number and channel name: WBTV 3.5 Oxygen and WCCB 18.9 MeTV Toons
Country: United States
Postal Code: 28092
Region/market: Charlotte NC
Plex Media Server version: 1.40.4.8679.
UK EPG Guide refresh still not working. Hasn’t been updated since last Thursday.
Not working form me in Melbourne, Australia. Originally I had data for some channels but I deleted DVR and reconfigured now all channels say “Unknown Airing”.
This error appears in the logs during a guide refresh…
[Req#3b544] EPG: received HTTP response of 502 from request to https://epg.provider.plex.tv/grid/bulk?channelGridKey=5fc70607052f6f002ef46651&endDate=2024-08-18&startDate=2024-08-12&X-Plex-Language=en&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
When configuring your DVR, try some neighbouring postcodes.
has anyone in the last month seen progress or feedback with getting their channels added, or is the nearby zip code the only option? thanks!
