Plex Media Server - Synology DSM 7 Preview - Issues ( Archive )
@thedingding
If you can wait a few days, you’ll have regular access to the Plex data.
It will be accessible again as the “PlexMediaServer” shared folder.
(I managed some dark magic)
I can give you the working preview now if you’d like.
Preview would be great!!! I can wait. I wanted to install the preview but I just couldn’t talk myself into installing it.
  1. READ – Please :slight_smile: I explain everything.
  2. I am likely to break fingers for those who don’t read :smiling_imp:
  3. Once installed, which might take a few moments based on your system to reorganize, you’ll have easy access for Backups and emergency access to the server internals.
I put the 1.24.2.4955 (alpha) build of PMS up for us to use.
  1. It’s pre-official QA testing. PMS seems OK but still might have issues functionally
  2. Packaging wise — SOLID! :partying_face:
I am interested but I’d rather wait for proper release if that’s ok.
This is my migration log if you need it. (no errors :slight_smile: )
Plex Media Server migration to DSM 7 started: Sun Aug 1 03:48:37 EEST 2021
=== Sun Aug 1 03:48:37 EEST 2021 === Start: Change ownership
=== Sun Aug 1 03:49:35 EEST 2021 === Completed: Change ownership
=== Sun Aug 1 03:49:35 EEST 2021 === Start: Convert symbolic links
=== Sun Aug 1 04:13:57 EEST 2021 === Completed: Convert symbolic links
=== Sun Aug 1 04:13:57 EEST 2021 === Start: Migrate Plex Media Server
=== Sun Aug 1 04:28:17 EEST 2021 === Completed: Migrate Plex Media Server
=== Sun Aug 1 04:28:17 EEST 2021 === Start: Clean /volume1/Plex
=== Sun Aug 1 04:28:17 EEST 2021 === Completed: Clean /volume1/Plex
LAST question since we have probably sorted everything out.
What should i choose when I install the upgrade? Does it matter? It’s just logs :confused:
If I install the preview should i choose “pms internal location”? I suppose that’s the new hidden pms folder?
PS: THANK YOU SO MUCH FOR ALL YOUR TIME!
My installation seems to have worked. Plex still works fine. The Plex is empty and only have the Migration.log file. But now I just can’t really see where the files should be.
But my only main problem seems to be for when I’m adding new files to my TV Shows Library, Plex doens’t automatically anymore when they are added.
It is updating my movie library automatically when I add a movie to my movie folder.
So it is TV Shows with season and all that doesn’t automatically update. I have to manually choose Scan Library.
Does anybody maybe have an idea to solution?
I just followed the instructions to update Plex for DSM7. There are two problems I still have.
  1. image
    Plex can not recognize my server. This is on PC in chrome.
    2)When I am on android on the app I can click on these libraries anyway. I see all my files are there, I can navigate to specific episodes and even hear the theme music playing. But when I press play I get the error "There was an error navigating to the specified item. Please make sure you are connected to the internet and try again.
Please advise on how to solve these issues. I have the same problems on my Nvidia shield (tube) which makes me suspect that is is on the server side, but I’m not very knowledgeable on this topic.
Thanks in advance.
After migration is complete, the “Plex” shared folder will be empty. I explained it all here in the documentation.
When you installed DSM 7, DSM 7 overwrote the custom Notify buffer size setting you had.
You need set it again.
Which instructions please?
If you used the migration instructions from the forum (my instructions), Please confirm the Plex shared folder is empty
There are multiple answers here :smiling_imp:
  1. The default condition (keep current) tells me to not touch anything
  2. Use PMS internal storage means "Write to the Logs directory under Plex Media Server
  3. Tell PMS where to write means that you want your logs somewhere else. Maybe you want all apps to put their logs in a common shared folder ?
OMG THANKS!! That did it. Adding permission to my Media folder.
Is this where I start waving around a big thick :open_book: ?
:rofl:
I guess this was asked before but after the migration is completed successfully, can we safely remove the Plex shared folder (that now only contains the Migration.log) as well as the old ‘plex’ user?
Yes and yes. :slight_smile:
I might have an interesting situation on an older DS214.
After migrating to DSM7 I removed all previous Plex version folders & users (or tried to), then tried a clean install.
Unfortunately I didn’t manage to avoid issues. With both versions I tried Plex tries to start, but stops soon after.
  • PlexMediaServer-1.24.1.4931-1a38e63c6-armv7hf_DSM7.spk - this one didn’t even create the PlexMediaServer folder
  • PlexMediaServer-1.24.2.4955-d26a2afaa-armv7hf_DSM7.spk - this one created the folder, but seems to start with a blank sqlite3 database.
Here’s a log from the latest attempt:
Aug 26, 2021 19:18:29.850 [0x2e763d48] INFO - Plex Media Server v1.24.2.4955-d26a2afaa - Synology DS214 armv7l - build: linux-armv7hf synology-dsm7 - GMT 03:00
Aug 26, 2021 19:18:29.851 [0x2e763d48] INFO - Linux version: DSM 7.0.41890-0, language: en-US
Aug 26, 2021 19:18:29.852 [0x2e763d48] INFO - Processor Arm
Aug 26, 2021 19:18:29.852 [0x2e763d48] INFO - Compiler is - Clang 11.0.1 (https://plex.tv e0c29d5827bc4eaaa2ceb882cbeed224b0960173)
Aug 26, 2021 19:18:29.852 [0x2e763d48] INFO - /volume1/@appstore/PlexMediaServer/Plex Media Server
Aug 26, 2021 19:18:30.219 [0x2b5dbe90] DEBUG - BPQ: [Idle] -> [Starting]
Aug 26, 2021 19:18:31.084 [0x2b5dbe90] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.35.5, threadsafe=1
Aug 26, 2021 19:18:31.605 [0x2e68bd48] DEBUG - [JobRunner] Job running: '/volume1/@appstore/PlexMediaServer/CrashUploader' '--directory=/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Crash Reports/1.24.2.4955-d26a2afaa' '--version=1.24.2.4955-d26a2afaa' '--platform=Linux' '--platformVersion=DSM 7.0.41890-0' '--serverUuid=' '--userId=NOUSERID' '--sentryUrl=https://sentry.io/api/1233455/minidump' '--sentryKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx' '--vendor=Synology' '--model=armv7l' '--device=DS214' '--allowRetries=0'
Aug 26, 2021 19:18:31.777 [0x2e68bd48] DEBUG - [JobRunner] Jobs: Starting child process with pid 19665
Aug 26, 2021 19:18:31.794 [0x2b5dbe90] DEBUG - Running migrations. (EPG 0)
Aug 26, 2021 19:18:31.794 [0x2b5dbe90] ERROR - SQLITE3:(nil), 1, no such table: schema_migrations in "select version from schema_migrations order by version"
Aug 26, 2021 19:18:32.138 [0x2b5dbe90] ERROR - Database corruption: sqlite3_statement_backend::prepare: no such table: schema_migrations for SQL: select version from schema_migrations order by version
The database files don’t seem to be corrupted, but just empty:
Is there maybe a DB initialization script that didn’t run? (and that I could run manually).
Update #1: I just noticed the otherwise obvious “Couldn’t copy file” error - I guess it’s a leftover from a previous install. I’ll clean that up & retry.
Update #2: Ran an ls after uninstalling & rebooting - doesn’t seem to be old leftover files:
ls: cannot access '/volume1/@appstore/PlexMediaServer/Resources': No such file or directory
ls: cannot access '/volume2/@appstore/PlexMediaServer/Resources': No such file or directory
Update #3: After copying the db template via:
cp "/volume1/@appstore/PlexMediaServer/Resources/com.plexapp.plugins.library.db" "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db"
I got the same problem for another DB:
Aug 27, 2021 12:17:38.573 [0x2b651e90] DEBUG - Opening 2 database sessions to library (com.plexapp.plugins.library.blobs), SQLite 3.35.5, threadsafe=1
Aug 27, 2021 12:17:38.587 [0x2b651e90] DEBUG - Installing Library Database from ["/volume1/@appstore/PlexMediaServer/Resources/com.plexapp.plugins.library.db"] to ["/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.blobs.db"]
Aug 27, 2021 12:17:38.587 [0x2b651e90] ERROR - Couldn't copy file "/volume1/@appstore/PlexMediaServer/Resources/com.plexapp.plugins.library.db" to "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.blobs.db": Invalid argument
Aug 27, 2021 12:17:38.684 [0x2b651e90] DEBUG - Running migrations. (EPG 0)
Aug 27, 2021 12:17:38.684 [0x2b651e90] ERROR - SQLITE3:(nil), 1, no such table: schema_migrations in "select version from schema_migrations order by version"
Aug 27, 2021 12:17:38.697 [0x2b651e90] ERROR - Database corruption: sqlite3_statement_backend::prepare: no such table: schema_migrations for SQL: select version from schema_migrations order by version
Aug 27, 2021 12:17:38.697 [0x2b651e90] ERROR - Error: Unable to set up server: sqlite3_statement_backend::prepare: no such table: schema_migrations for SQL: select version from schema_migrations order by version (N4soci10soci_errorE)
That one got fixed with another manualy copy (after deleting the blank files):
cp "/volume1/@appstore/PlexMediaServer/Resources/com.plexapp.plugins.library.db" "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.blobs.db"
So now it starts… but there’s still some issues:
Aug 27, 2021 12:23:17.575 [0x2b658e90] ERROR - Couldn't install default combiner for com.plexapp.agents.imdb: boost::filesystem::copy_file: Invalid argument: "/volume1/@appstore/PlexMediaServer/Resources/imdb-combiner-movies.xml", "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/com.plexapp.agents.imdb/Movies.xml"
Aug 27, 2021 12:23:17.576 [0x2b658e90] ERROR - Couldn't install default combiner for com.plexapp.agents.themoviedb: boost::filesystem::copy_file: Invalid argument: "/volume1/@appstore/PlexMediaServer/Resources/themoviedb-combiner-movies.xml", "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/com.plexapp.agents.themoviedb/Movies.xml"
Aug 27, 2021 12:23:17.577 [0x2b658e90] ERROR - Couldn't install default combiner for com.plexapp.agents.thetvdb: boost::filesystem::copy_file: Invalid argument: "/volume1/@appstore/PlexMediaServer/Resources/thetvdb-combiner-shows.xml", "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/com.plexapp.agents.thetvdb/TV Shows.xml"
Aug 27, 2021 12:23:17.578 [0x2b658e90] ERROR - Couldn't install default combiner for com.plexapp.agents.lastfm: boost::filesystem::copy_file: Invalid argument: "/volume1/@appstore/PlexMediaServer/Resources/lastfm-combiner-artists.xml", "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/com.plexapp.agents.lastfm/Artists.xml"
Aug 27, 2021 12:23:17.579 [0x2b658e90] ERROR - Couldn't install default combiner for com.plexapp.agents.lastfm: boost::filesystem::copy_file: Invalid argument: "/volume1/@appstore/PlexMediaServer/Resources/lastfm-combiner-albums.xml", "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/com.plexapp.agents.lastfm/Albums.xml"
Aug 27, 2021 12:23:17.581 [0x2b658e90] ERROR - Couldn't install default combiner for com.plexapp.agents.none: boost::filesystem::copy_file: Invalid argument: "/volume1/@appstore/PlexMediaServer/Resources/none-combiner-movies.xml", "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/com.plexapp.agents.none/Movies.xml"
Aug 27, 2021 12:23:17.581 [0x2b658e90] ERROR - Couldn't install default combiner for com.plexapp.agents.none: boost::filesystem::copy_file: Invalid argument: "/volume1/@appstore/PlexMediaServer/Resources/none-combiner-shows.xml", "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/com.plexapp.agents.none/TV Shows.xml"
Aug 27, 2021 12:23:17.583 [0x2b658e90] ERROR - Couldn't install default combiner for com.plexapp.agents.none: boost::filesystem::copy_file: Invalid argument: "/volume1/@appstore/PlexMediaServer/Resources/none-combiner-artists.xml", "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/com.plexapp.agents.none/Artists.xml"
Aug 27, 2021 12:23:17.584 [0x2b658e90] ERROR - Couldn't install default combiner for com.plexapp.agents.none: boost::filesystem::copy_file: Invalid argument: "/volume1/@appstore/PlexMediaServer/Resources/none-combiner-albums.xml", "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/com.plexapp.agents.none/Albums.xml"
Aug 27, 2021 12:23:17.586 [0x2b658e90] ERROR - Couldn't install default combiner for com.plexapp.agents.localmedia: boost::filesystem::copy_file: Invalid argument: "/volume1/@appstore/PlexMediaServer/Resources/localmedia-combiner-movies.xml", "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/com.plexapp.agents.localmedia/Movies.xml"
Aug 27, 2021 12:23:17.586 [0x2b658e90] ERROR - Couldn't install default combiner for com.plexapp.agents.localmedia: boost::filesystem::copy_file: Invalid argument: "/volume1/@appstore/PlexMediaServer/Resources/localmedia-combiner-shows.xml", "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/com.plexapp.agents.localmedia/TV Shows.xml"
Aug 27, 2021 12:23:17.587 [0x2b658e90] ERROR - Couldn't install default combiner for com.plexapp.agents.localmedia: boost::filesystem::copy_file: Invalid argument: "/volume1/@appstore/PlexMediaServer/Resources/localmedia-combiner-artists.xml", "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/com.plexapp.agents.localmedia/Artists.xml"
Aug 27, 2021 12:23:17.588 [0x2b658e90] ERROR - Couldn't install default combiner for com.plexapp.agents.localmedia: boost::filesystem::copy_file: Invalid argument: "/volume1/@appstore/PlexMediaServer/Resources/localmedia-combiner-albums.xml", "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/com.plexapp.agents.localmedia/Albums.xml"
Aug 27, 2021 12:23:17.589 [0x2b658e90] ERROR - Couldn't install default combiner for tv.plex.agents.music: boost::filesystem::copy_file: Invalid argument: "/volume1/@appstore/PlexMediaServer/Resources/plex-music-combiner-artists.xml", "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/tv.plex.agents.music/Artists.xml"
Aug 27, 2021 12:23:17.590 [0x2b658e90] ERROR - Couldn't install default combiner for tv.plex.agents.music: boost::filesystem::copy_file: Invalid argument: "/volume1/@appstore/PlexMediaServer/Resources/plex-music-combiner-albums.xml", "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/tv.plex.agents.music/Albums.xml"
Aug 27, 2021 12:23:17.592 [0x2b658e90] ERROR - Couldn't install default combiner for org.musicbrainz.agents.music: boost::filesystem::copy_file: Invalid argument: "/volume1/@appstore/PlexMediaServer/Resources/musicbrainz-combiner-artists.xml", "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/org.musicbrainz.agents.music/Artists.xml"
Aug 27, 2021 12:23:17.593 [0x2b658e90] ERROR - Couldn't install default combiner for org.musicbrainz.agents.music: boost::filesystem::copy_file: Invalid argument: "/volume1/@appstore/PlexMediaServer/Resources/musicbrainz-combiner-artists.xml", "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Metadata Combination/org.musicbrainz.agents.music/Albums.xml"
Aug 27, 2021 12:23:17.593 [0x2b658e90] ERROR - Error ensuring agent com.plexapp.agents.lyricfind was enabled: Empty or non-existant file.
Aug 27, 2021 12:23:17.594 [0x2b658e90] ERROR - Error ensuring agent com.plexapp.agents.vevo was disabled: Empty or non-existant file.
Aug 27, 2021 12:23:17.599 [0x2b658e90] ERROR - Error ensuring agent com.plexapp.agents.lyricfind was enabled: Empty or non-existant file.
Aug 27, 2021 12:23:17.600 [0x2b658e90] ERROR - Error ensuring agent com.plexapp.agents.vevo was disabled: Empty or non-existant file.
Aug 27, 2021 12:23:17.869 [0x2b658e90] ERROR - Error ensuring agent com.plexapp.agents.lyricfind was enabled: Empty or non-existant file.
Aug 27, 2021 12:23:17.870 [0x2b658e90] ERROR - Error ensuring agent com.plexapp.agents.vevo was disabled: Empty or non-existant file.
Aug 27, 2021 12:23:17.871 [0x2b658e90] ERROR - Error ensuring agent com.plexapp.agents.vevo was disabled: Empty or non-existant file.
This doesn’t seem to be a permissions issue - maybe some different libraries / kernel… What do you think @ChuckPa?
$ ls -ahl /volume1/@appstore/PlexMediaServer
total 19M
drwxr-xr-x  5 PlexMediaServer PlexMediaServer 4.0K Aug 21 00:36 .
drwxr-xr-x  6 root            root            4.0K Aug 27 11:48 ..
-rwxr-xr-x  1 PlexMediaServer PlexMediaServer 477K Aug 21 00:17 CrashUploader
-rwxr-xr-x  1 PlexMediaServer PlexMediaServer 253K Aug 20 23:55 Plex Commercial Skipper
-rwxr-xr-x  1 PlexMediaServer PlexMediaServer 1.9M Aug 21 00:15 Plex DLNA Server
-rwxr-xr-x  1 PlexMediaServer PlexMediaServer  92K Aug 20 23:55 Plex Media Fingerprinter
-rwxr-xr-x  1 PlexMediaServer PlexMediaServer 2.6M Aug 21 00:18 Plex Media Scanner
-rwxr-xr-x  1 PlexMediaServer PlexMediaServer  11M Aug 21 00:23 Plex Media Server
-rwxr-xr-x  1 PlexMediaServer PlexMediaServer 486K Aug 20 23:55 Plex Relay
-rwxr-xr-x  1 PlexMediaServer PlexMediaServer 8.2K Aug 20 23:55 Plex SQLite
-rwxr-xr-x  1 PlexMediaServer PlexMediaServer 8.7K Aug 20 23:55 Plex Script Host
-rwxr-xr-x  1 PlexMediaServer PlexMediaServer 267K Aug 20 23:55 Plex Transcoder
-rwxr-xr-x  1 PlexMediaServer PlexMediaServer 2.6M Aug 20 23:55 Plex Tuner Service
drwxr-xr-x 10 PlexMediaServer PlexMediaServer 4.0K Aug 21 00:36 Resources
drwxr-xr-x  2 PlexMediaServer PlexMediaServer 4.0K Aug 21 00:23 lib
drwxr-xr-x  3 PlexMediaServer PlexMediaServer 4.0K Aug 21 00:36 ui
$ ls -ahl "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Plug-in Support"
total 28K
drwxrwxrwx+  7 PlexMediaServer PlexMediaServer 4.0K Aug 27 12:26 .
drwxrwxrwx+  8 PlexMediaServer PlexMediaServer 4.0K Aug 27 12:23 ..
drwxrwxrwx+ 19 PlexMediaServer PlexMediaServer 4.0K Aug 27 12:26 Caches
drwxrwxrwx+ 19 PlexMediaServer PlexMediaServer 4.0K Aug 27 12:26 Data
drwxrwxrwx+  2 PlexMediaServer PlexMediaServer 4.0K Aug 27 12:23 Databases
drwxrwxrwx+ 10 PlexMediaServer PlexMediaServer 4.0K Aug 27 12:23 Metadata Combination
drwxrwxrwx+  2 PlexMediaServer PlexMediaServer 4.0K Aug 27 12:26 Preferences
@psaxuf (aka: psefw :wink: )
The “alpha” package appears to have bitten you. Sorry about that.
There are several “Packaging 2.0” builds. Have you tried them all?
Also, where is your DB which you have been running on?
So I’ve had a few things happen with the migration. My first try I missed the Uninstall step and ended up with a new server with the same name. I used the migration script posted and did a un-install, re-install with claim token to fix that.
It was working for a day or so, but then stopped responding. I stopped it in Package manager, but then it wouldn’t start back up the log showed database corruption errors. I tried the database repair process with no luck and ended up restoring a database from before the update. It started up then and re-converted the database I believe.
It was working again for a day or so, but today I’m getting database corruption errors again in the log:
Aug 27, 2021 12:01:15.502 [0x7f0fd2b30b38] ERROR - SQLITE3:0x80000001, 11, database corruption at line 69874 of [1b256d97b5]
Aug 27, 2021 12:01:15.502 [0x7f0fd2b30b38] ERROR - SQLITE3:0x80000001, 11, statement aborts at 26: [select distinct metadata_items.id from metadata_items   join metadata_items as parents on metadata_items.parent_id=parents.id  join metadata_items as children on children.parent_id=met
I have attached the full log files.Plex Logs.zip (4.4 MB)
Hello @ChuckPa,
I have been trying to solve this problem for a week now. I did the manual install, I removed everything from plex of my NAS (even with SSH to manually take off everything that was left).
I can install my server manually. I can even claim it with the token. My plex.tv account will see that the server has logged in as I can see it in Authorized Devices.
However, plex.tv doesn’t see any servers. And if I log in with the same account I used to claim the server, when I log in on port 32400 on my server directly, it tells : Not Authorized, you do not have access to this server.
What am I supposed to do with this?
@ardech
Can you provide me with the log files?
I looked at your account on Plex.tv
I see “storinator” which was recently deleted. I don’t see any active server registered to your account.
This means one of two things:
  1. PMS can’t connect to plex.tv
  2. PMS is connecting to a different account
Your logs, collected about 2 minutes after startup, will tell me what is happening (it logs in during that startup)
Also. which DSM 7 package version are you using?
I cannot find the plex log file. The location specified here does not exist : Where is the Plex Media Server data directory located? | Plex Support
I see no shared folder for Plex (I had to delete the old one called Plex on DSM6 because it was impossible to read/write in any way after the upgrade. I’m trying to fresh install)
As for Storinator, that is the one I’m trying to get to join again with a fresh install because I wasn’t able to repair the old instance
But I can guarantee that it’s the correct account (confirmed upon install with the token. You get a message with the account that has successfully been joined)
And I can see him in authorized access. As for connection to plex.tv, that is also tested and it’s fully capable to connect to it through the network…
