DSM 7 - Finalized Configuration (PMS 1.24.2.4973) - Release information
DSM 7 - Finalized Configuration (Packaging 2.0) - Release Information
See below for updates
Since DSM 7.0-41890 finalized, I’ve had time to digest everyone’s input as well as review what we ultimately ended up with in DSM 7.0
Looking at all the issues faced, there was one overriding problem which could not be solved – Plex’s data was not accessible from the GUI or other Synology tools such as Hyper Backup.
An important issue for most was the data area could not be moved.
It took some time but I figured out how to reliably get us as close to the DSM 6 style shared folder structure as DSM 7 will allow.
With the changes here, I’ve managed to give us the freedom to place the PlexMediaServer shared folder on any of the numeric (internal) volumes (e.g. volume1 - volume99). DSM 7 won’t permit the shared folder on other volumes.
Structure changes:
  1. Created shared folder PlexMediaServer
  2. Created a different directory structure which should avoid confusion moving forward.
  • AppData - All PMS application data is here.
  • AppData/tmp - Used for codecs and as default TMP directory.
  • AppData/Plex Media Server - The main “Plex Media Server” data storage.
  1. PlexMediaServer is only visible to administrators and system internal user PlexMediaServer. (DSM 7 overrides ACLs set when PMS starts)
Migration & Relocation
  1. New installations of PMS will use the new storage structure.
  2. All existing DSM 6 → DSM 7 migration procedure steps remain unchanged
  3. Migration is now able to find and migrate edge cases plex or Plex.
  • The first-found directory with PMS data in it will be selected.
  • There is no way to arbitrate in the automation.
  1. Relocation of an existing DSM 7 installation is automatic when updating.
  2. Installation is restricted to internal Volumes (1-99)
Limitations:
The following limitations still exist and unfortunately cannot be changed.
  1. System Internal User PlexMediaServer cannot be accessed in File Station. It can only be accessed in the Control Panel - Shared Folders for the sake of setting shared permissions (which DSM does automatically)
  2. If file permissions or ownership are altered then a User-Script scheduled task or manual intervention on the command line will correct the problem.
  3. DSM 7 is restrictive and fragile. Please be 100% certain of what you are doing if you access the PlexMediaServer/AppData folder. You are urged to only make alterations as provided by the installer GUI or under the directions of a Plex Ninja or staff member .
  4. It is recommended to increase the default logout time period from the default of 60 minutes to something longer… up to 65535 .. so you are guaranteed to get the popup at the end of initial migration.
WARNINGS:
DO NOT PLACE MEDIA ANYWHERE INSIDE THE PlexMediaServer SHARED FOLDER
  • Just as with DSM 6, put media in the wrong place and bad things happen.
  • Media can be placed anywhere else on the NAS except here.
  • NOTHING is gained by putting media in this shared folder.
Why not put media in the PlexMediaServer shared folder?
  1. Should you make a mistake and have PMS index AppData, your server will lock up and you’ll be forced to erase and start over
  2. Backing up your PMS installation with HyperBackup will be much more complex and, when restoring, you could end up losing media. (worst case)
  3. We make these recommendations because:
    a. I know how it was designed and written.
    b. We’ve seen the horror stories when it goes sideways and data is lost.
    c. We’ve spent countless hours trying to help folks undo damage only to be forced into a full “erase & reload” scenario.
  4. Please don’t listen to the “Internet Experts”. Help is freely given and tailored to how you’d like to use your NAS in your environment.
Technical Implementation details:
  1. Shared Folder: PlexMediaServer
  2. Contents: AppData (application data) directory which contains:
    a. tmp - temp directory for codecs (required). Default transcoder temp
    b. Plex Media Server - core PMS data storage
   /volume*
     PlexMediaServer/
       AppData/
         tmp/
         Plex Media Server/
  1. PlexMediaServer continues to be a non-privileged application running in a constrained environment on DSM 7.
We have a General Discussion thread here for loosely related chat. Please do create a new thread somewhere for all other (non-preview related) technical issues.:
https://forums.plex.tv/t/dsm-7-packaging-2-0-forum-preview-discussion/732912
Warning
PMS 1.24.2.4973 – Packaging 2.0 now available.
  1. Package Center – Do not use the Synology 3744 beta build. It’s too old.
  2. Plex.tv/downloads – Min usable version 1.24.2.4973
FINAL CAUTION
Do not revert to any version below 1.24.2.4973 once you’ve made the transition. There is no backward compatibility with the older packaging (sorry).
Update: 22-Sep-2021
The Installation and Update GUI will be changing slightly in an upcoming release.
The log file redirection feature is being removed.
This isn’t needed anymore since the entire shared folder is now visible.
Also the confirmation pages are being removed as they are superfluous
Please don’t be surprised at the minor change. It will streamline package management.
Plex media server install problem when upgraded to DSM7
DSM 7 + Plex Upgrade/Migration Issue
I can't add/update plugins (Agents, Metadatas) with DSM7, HELP
Plex Media Server - Synology DSM 7 Preview - Issues ( Archive )
Tautulli cannot get plex log from DSM7
Plex Logs in Tautulli
Synology 218+ with DSM 7 - NAS not detected
Umzug Plex von DS1815 zu DS1819 - unter DSM 7
What's the best practice for updating Plex in Synology DSM7?
Synology DSM 7 - Plex Media Server Installation Issue
Plex created a shared folder on my synology
Can't play media on Android/Firestick/Nvidia devices
Plex not working properly after DMS7 Update
Plex Server cannot handle transcoding with subtitles
Plex library didn't migrate with dsm7 update
Multiple Plex folders after 1.24.2.4973-2b1b51db9 Synology 7 instal
Installed numerous times - will not recognise a single file
DSM 7 - Plex Media Server - Release Info & Migration instructions
Cannot locate Plex shared folder or plexmediaserver user on synology nas
DSM 7 files not available
Where is the Plex Media Server data directory located for Synology NAS DSM 7
Sonic Analysis - has processed 6 albums in 40 minutes
Location of Plex Media Server Files (specifically plug-in for Audible metadata) on DSM-7
Plex stops immediately after starting (fresh install)
Plex migration from other platform to DSM 7
How do I backup my Plex data (not media) on Synology NAS with DSM7?
Plex server goes wild, consumes all memory then stops (database corruption?)
Installing Plex on a Synology NAS
Synology - How do I undo my botched DSM7 migration?
Plex in DSM 7 doesn't detect my NAS
Plex & DSM 7.0 - What happened to my indivdual folders in 'add library' guys?
Movies will not play after update to DSM 7
Can't open Media Server after updating to 1.24.5.5173 (Synology DSM7)
Plex server does not see subfolders of Shared folder
Reconnecting to Synology NAS
DSM7 - New NAS for existing Home User - No acces tot server (migration home user to own PlexServer)
Got locked out of Media Server
New Plex Server on Synology DS920+
Unable re-install Plex on NAS on DSM 6.X
Synology DS1520+ Plex Server Setup Issues
Playback error Synology DSM 7
Upgrading to Synology DSM 7 without granting read/write to PlexMediaServer
Issue with upgrading library
Media Libraries not available
Problem updating Plex 1.25.6.5545 to 1.25.6.5577
Can i delete the "old" plex folder after dsm migration to plexmediaserver folder?
PMS 1.25.8 not installing on DSM7
Movies not getting added to Plex
Synology: DSM 7 Installation Archive -- Archived from main thread
Plex manual server synology update keeps forever "processing. Please wait..."
Migrating from Plex Media Server Windows to Synology without loss?
Request for Input - Change Plex storage structure on Synology
Synology DSM 7
Dsm7 - can’t find plex library to backup
222 posts were merged into an existing topic: Plex Media Server - Synology DSM 7 Preview - Issues ( Archive )
11 posts were merged into an existing topic: DSM 7 - Packaging 2.0 - Forum Preview - Discussion
