Synology - DSM 7.0 Release - Plex Installation (Not Operational) Issues
Not fixed.
Sticking a pin in it –
As of build 1.32.6.7371-b6a09ad81., Gemini Lake CPU HW transcoding is still broken.
We’re still recouping from the staffing changes.
Hi, I have a dS1019 and its on version 6.2.4-25556 update 7. I wanted to migrate this over to DSM 7.1.1 +. I found this URL that talked about how to upgrade and migrate plex. Is this still a good and valid guide or is there something else i need to do before i do any upgrade?
My main goal is to have a seamless migration and I don’t lose my setup, shares and watch history.
Please let me know if this is where i should start or some place else. Thx.
The process shown is a little bit out of date but still valid.
If you’re comfortable with it then use it. It hits all the important steps.
Migrated my ds414 to dsm 7 over the weekend using the guide. Plex Media Server is running fine, but playback is awful. Loading the content takes a long time, then a few seconds play, then I get the too slow to play properly message. Playback had always been fine on dsm 6. Anyone experiencing performance issues?
Edit: looks like it’s limited to apple tv. Playback via web interface and the ipad app is working fine; unusable on apple tv
@ChuckPa
Do you have something new for this problem ?
Thank you
which problem please? This thread is crazy long (I should archive a lot of it)
EDIT: I have archived from Jan → Jul in the DSM 7 archive thread.
About the search problem. You have provide me a older version for the test. With this version the search works. You remember it?
Firstly, I found this post very helpful. Thanks.
After updating my Synology to v7 I found a few things I’m trying to workout/fix.
When I first installed Plex I had the following directories:
/homes/plex/www
/plex
After this update I also had
  • PlexMediaServer
I don’t believe this was there before.
I placed all my media files in
/homes/plex/www
My questions.
  1. Can I delete the /plex folder?
  2. Where should I be placing my media files?
  3. Within the plex app, I had to setup the server again so the old server is still there, how do I delete it?
  4. Is there a way to copy across library information such ‘watched’ etc as all my media has now changed to unwatched.
Thanks in advance.
@jaztek
  1. The Plex shared folder is from DSM 6 Plex. All the metadata was stored there
  2. The PlexMediaServer shared folder is for DSM 7. We had to change all the names for DSM 7 so everything became PlexMediaServer
  3. I recommend not putting media in /home/plex .
    If you ever delete user Plex, you’ll delete all your media too. – NOT GOOD
    RECOMMEND: Create a shared folder “Media” or “Movies”, “TV”, etc.
    Whatever you like, and put your media there where it’s safe
  4. Moving all your DSM 6 metadata (watch history + customizations) is called “migration”. The package knows how to do all this as part of the installation process. When conditions are right, it will convert all your DSM 6 Plex data to DSM 7 format and then move it into PlexMediaServer.
  • The biggest requirement is:
    – We uninstall the DSM 7 package
    – We DELETE the DSM 7 instance which was created
    – We have to manually set permissions for PlexMediaServer to move files from “Plex” shared folder (DSM 7 took away all those privileges)
  • When the conditions are met, the package will do all the converting and moving for us. In the end, “Plex” will have all the old files removed. Everything for your server will be now native to DSM 7.
Does this sound ok for you?
Hi everybody!
On PlexMediaServer-1.32.6.7468-07e0d4a7e-x86_64_DSM7 apollolake transcoder return broken. Was fine ultil 7371.
Could you post previous version spk?
@vertigo8u
Can you please post Server DEBUG logs which capture the start of a transcode playback so I can confirm what’s happening?
(I’ll need it to fix it if indeed broken)
@ChuckPa
Here the logs zip attached.
Plex Media Server Logs_2023-08-31_19-33-02.zip (4.9 MB)
Aug 31, 2023 19:28:41.835 [139836258777912] DEBUG - [Req#2e9/Transcode] Codecs: dummy-frame test succeeded
Aug 31, 2023 19:28:41.836 [139836258777912] DEBUG - [Req#2e9/Transcode] MDE: Selected protocol hls; container: mpegts
Aug 31, 2023 19:28:41.836 [139836258777912] DEBUG - [Req#2e9/Transcode] MDE: analyzing media item 97337
Aug 31, 2023 19:28:41.836 [139836258777912] DEBUG - [Req#2e9/Transcode] MDE: Shark 2 - L'abisso (2023): Direct Play is disabled
Aug 31, 2023 19:28:41.836 [139836258777912] DEBUG - [Req#2e9/Transcode] MDE: Shark 2 - L'abisso (2023): media must be transcoded in order to use the hls protocol
Aug 31, 2023 19:28:41.836 [139836258777912] DEBUG - [Req#2e9/Transcode] MDE: Shark 2 - L'abisso (2023): selected subtitle cannot be converted to a compatible format, burning into video stream
Aug 31, 2023 19:28:41.836 [139836258777912] DEBUG - [Req#2e9/Transcode] MDE: Shark 2 - L'abisso (2023): Direct Streaming is disabled, so video stream will be transcoded
Aug 31, 2023 19:28:41.836 [139836258777912] DEBUG - [Req#2e9/Transcode] MDE: Shark 2 - L'abisso (2023): no remuxable profile found, so video stream will be transcoded
Aug 31, 2023 19:28:41.837 [139836258777912] DEBUG - [Req#2e9/Transcode] MDE: Cannot direct stream video stream due to profile or setting limitations
Aug 31, 2023 19:28:41.837 [139836258777912] DEBUG - [Req#2e9/Transcode] Codecs: testing hevc (decoder) with hwdevice vaapi
Aug 31, 2023 19:28:41.837 [139836258777912] DEBUG - [Req#2e9/Transcode] Codecs: hardware transcoding: testing API vaapi for device '/dev/dri/renderD128' (HD Graphics 500)
You’re still getting HW transcoding (Decode and Encode). You’re also having to cope with Subtitle burning by the CPU which a Syno is NOT very good at.
I installed previous version 7371 and HW Transcoding works fine (20% cpu usage including subs). Find attached server logs with 7371.
Plex Media Server Logs_2023-08-31_22-22-17.zip (4.5 MB)
@vertigo8u
Looks like a ASS subtitle handling regression caused by the subtitle handling fix.
OOPS.
I’ve filed the issue .
I found another bug in the package structure. :slightly_smiling_face:
conf/PlexMediaServer.sc it is registered in the “resource” file
"port-config": "conf/PlexMediaServer.sc"
but it doesn’t work that way in DSM7.
If you look https://help.synology.com/developer-guide/resource_acquisition/port_config.html
it should be like this
"port-config": {
    "protocol-file": "ui/PlexMediaServer.sc"
and must be located under /var/package/{$package}/target/ui/
I appreciate the feedback.
Where’s the rest of that chain so I can walk through from the resource → actual port list specification ?
Given the configuration file calls out ui/PlexMediaServer.sc, must it be in ui/ ?
I’m also very curious why, given Synology inspects and approves our packages in Package Center, why it would be permitted if it was completely in error ?
I’ll make the changes once I understand what and why the changes are needed.
EDIT:
I already have it this way:
	"video-driver": {},
	"port-config": "conf/PlexMediaServer.sc",
	"data-share": {
		"shares": [{
			"name": "PlexMediaServer",
			"permission": {
				"rw": ["PlexMediaServer"]
		"once": "false"
@vladlenas
Further on this problem:
bash-4.4# ls
conf  etc  home  INFO  scripts	share  shares  target  tmp  var  WIZARD_UIFILES
bash-4.4#
bash-4.4#
bash-4.4# ls target/ui
config	images	PlexMediaServer.sc
bash-4.4# cat target/ui/PlexMediaServer.sc
[PlexMediaServer]
title="PlexMediaServer"
desc="PlexMediaServer"
port_forward="yes"
dst.ports="32400/tcp,32401/tcp,32469/tcp,32600/tcp,3005/tcp,8324/tcp,1900/udp,32410/udp,32412/udp,32413/udp,32414/udp"
bash-4.4# /usr/syno/sbin/synopkghelper update PlexMediaServer port-config
synopkghelper: json_value.cpp:1442: Json::Value& Json::Value::resolveReference(const char*, bool): Assertion `type_ == nullValue || type_ == objectValue' failed.
Aborted (core dumped)
bash-4.4#
	"video-driver": {},
    "port-config": {
	"data-share": {
		"shares": [{
			"permission": {
		"once": "false"
It should be like this, please note that I gave the ui directory as an example. You can put this file anywhere, but it must be in /var/package/PlexMediaServe/target/your_folder/PlexMediaServer.sc. In the package .spk it must be compressed in package.tgz.
