iTunes playlist conundrum in Plexamp
I have curated my music in iTunes for many years and it’s been solid and dependable. I moved to Plex/Plexamp recently and I’m delighted with the experience. My workflow is still the same, I add new tacks in iTunes and see Plex update in real time as expected.
Here’s the thing, I have a bunch of regular and smart playlists in my iTunes library and when I try to update them in Plex (by using Import from iTunes… from the Playlist Actions button and checking overwrite existing playlists) I inevitably get the error “something went wrong”. However, the playlists will slowly update but it will take a few minutes. The strange thing is that playlists will appear that I created weeks ago and had since deleted. It’s as if Plex is updating iTunes playlists to a random point in the past not the current state. It’s very strange behaviour!
I’ve tried to use Plex to create the same playlists but it’s a painful experience since the options are so different from iTunes.
Can anyone explain what’s happening or suggest a more reliable way to introduce/update playlists. I am completely baffled!
(First time poster using Mac OS)
This is likely the issue. Plex cannot recreate the Playlist so you are getting unexpected results. I thought plex stopped trying to recreate smart playlists from iTunes, guess not. This has always been an issue.
No problem. I was being a bit precious with my playlists. Plexamp has some great radios and random features, combined with great guest DJs making for a real adventure. Gonna start living life on the edge from now on!!!
What criteria / filter options are you missing to replicate those smart playlists from iTunes in Plex?
These are some of the iTunes options I use. Plexamp filter options are very different and not intuitive.
I take it you won’t be able to filter your Plex library based on if a song was purchased from iTunes or not :wink:
As for “not intuitive” – I tend to disagree.
Personally I find the Apple Music / iTunes filtering clunky as all attributes are dumped on you alphabetically while Plex (especially Plexamp) group them for the various tiers of a song (artist / album / track).
That being said and given your screenshot isn’t answering what you’re trying to filter which you can’t do in Plex Web or Plexamp.
Artist
Plexamp iTunes
:white_check_mark: :pencil: Name :white_check_mark: Album Artist
:white_check_mark: Artist
– :white_check_mark: Sort Album Artist
:white_check_mark: Sort Artist
:white_check_mark: :label: Genre –
:white_check_mark: :label: Style –
:white_check_mark: :label: Collection –
:white_check_mark: :globe_with_meridians: Country –
:white_check_mark: :star: Rating –
:white_check_mark: :date: Added –
:white_check_mark: :date: Last Played –
:white_check_mark: :1234: Plays –
Album
Plexamp iTunes
:white_check_mark: :label: Mood –
:white_check_mark: :label: Format –
:white_check_mark: :label: Type – (a subset of this is reflected in iTunes’ Compilation flag)
:white_check_mark: :date: Date Released –
:white_check_mark: :date: Year Released :white_check_mark: Year
:white_check_mark: :date: Decade Released –
:white_check_mark: :optical_disk: Record Label –
:white_check_mark: :star: Critic Rating –
:white_check_mark: :star: Rating :white_check_mark: Album Rating
– [1] :white_check_mark: Album Artwork (yes/no)
Track
Plexamp iTunes
:white_check_mark: :pencil: Name :white_check_mark: Title
:white_check_mark: :date: Last Played :white_check_mark: Last Played
:white_check_mark: :date: Last Skipped :white_check_mark: Last Skipped
:white_check_mark: :1234: Plays :white_check_mark: Plays
:white_check_mark: :1234: Skips :white_check_mark: Skips
:white_check_mark: :star: Rating :white_check_mark: Rating
:white_check_mark: :date: Rated –
:white_check_mark: :date: Added :white_check_mark: Date Added
– [2] :white_check_mark: Date Modified
:white_check_mark: :label: Genre :white_check_mark: Genre
– :white_check_mark: Category
– [3] :white_check_mark: Playlist
:white_check_mark: :watch: Duration :white_check_mark: Time
:white_check_mark: :antenna_bars: Bitrate :white_check_mark: Bit Rate
– [4][5] :white_check_mark: BPM
:white_check_mark: :antenna_bars: Codec –
– [6] :white_check_mark: Sample Rate
:white_check_mark: :1234: Popularity –
– :white_check_mark: Comments
– [7] :white_check_mark: Disc Number
:white_check_mark: Track Number
– [8] :white_check_mark: Size
Some iTunes specific stuff
There’s a few filter options specific to iTunes based on how iTunes manages media.
  • Album Favorite / Suggest Less and [Track] Favorite / Suggest Less
  • Cloud Status
  • Purchased
  • Media Kind is implied in Plex as you’re dealing with media of a particular library
  • Video Rating, Sort Show and Description apply to other media types
  • Grouping – seems to be a free-text field in iTunes; probably matches Plex’s Label which can only be filtered in the web app.
Open Features in Plex/Plexamp
Plex currently has no concept of…
  • Checked items [9][10]
  • Composer (therefore also no ´Sort Composer`)
  • Movement (Name, Number), and Work
Plex supports filtering by library folders in the web app, but has no concept of filtering by the exact path of a file (Location)
  1. Feature Suggestion: Custom filter for missing artwork ↩︎
  2. Feature Suggestion: Filter by file date ↩︎
  3. Feature Suggestion: Playlist Presence Filtering ↩︎
  4. Feature Suggestion: BPM Metadata ↩︎
  5. Feature Suggestion: Automatic detection + playlist creation ↩︎
  6. Feature Suggestion: Filter by Sample Rate and Bit Depth ↩︎
  7. Feature Suggestion: Filter Music by Track Numbers ↩︎
  8. Feature Suggestion: Filtering by Audio and File Size ↩︎
  9. Feature Suggestion: Ability to exclude media from Shuffle Modes ↩︎
  10. Feature Suggestion: Option to toggle to always skip songs ↩︎
Thanks for the input, it’s very thorough.
For years I’ve been using the composer tag in iTunes to add my own moods/style for every track. I have about 25 smart playlists based on these styles and it works great for me in iTunes. I was trying to mimic this in Plexamp.
Incidentally, the styles I use are not based on genres but on “mood” images. Sounds odd but I find it easier to visualize music this way.
Example playlists (imported from iTunes)
So basically, you used a metadata attribute in iTunes for a different purpose.
This attribute is however not supported / available in Plex. Hence you can’t filter for your custom moods.
There’s a number of feature suggestions with regards to Plex supporting that particular attribute [1][2] – that being said, not sure if it’ll help you as you’re not using it for the composer but to reflect some custom categorization.
If you don’t care for the Mood/Style information in Plex, you could try to transfer your custom Composer values to one of those. I don’t have a tool at hand, but I’m sure there’s some scripts that’ll do that.
  1. Feature Suggestion: Filter by Composer ↩︎
  2. Feature Suggestion: Wider native support for embedded metadata ↩︎
Many thanks for the input. I’ll have a go at using one of the Plex mood or style categories Nd try to bend it to my will. Hopefully I can find a way of batch processing this. I think there is an app that can help me do this. :+1:
