Server Version#: 1.25
Hi all,
I just bought and setup my first syno (ds920+).
I did add my library and tried to install plex media server from Both syno app store pr manual install using plex’s latest version !
Both are failing to access my storage…
I tried to use a différent folder than /homes/…, I’m using a /volume1/library folder. I also fixed the permissions but nothing is working…
ChuckPa
December 11, 2021, 11:24pm
2
@jsn_crdnl_gmail_com
You must give PlexMediaServer access to the media
Control panel - Shared Folders - Click the shared folder → EDIT
Permission tab
ADD “System Internal User” (click Local user dropdown to show), ‘PlexMediaServer’.
Give it whatever permissions you wish.
DSM 7 - Set permissions for (Media) Shared Folders.
Often, when upgrading, changing permissions from Plex to PlexMediaServer is overlooked.
Sometimes, folders have mismatched permissions within them.
Here is how you remedy the problem.
That message you see at the end of installation is a reminder to you to go check and provides the instructions how to remedy it.
It may not address all problems but does address the vast majority.
File Station → Right-click the shared folder → Propert…
Sadly, that’s exactly what I did (on multiple shares), as suggested at install, with no results..
Here are the error screen I get:
ChuckPa
December 12, 2021, 5:38am
4
Do not use QuickConnect to setup Plex.
Use the LAN IP of the NAS.
AFTER you setup Plex then you can use it.
DSM QuickConnect causes a REMOTE connection. Default Plex security blocks this.
Wow !!! You made made my day ! Many thanks !!
I didn’t know the dns could be an issue !
You should add this info in the installation disclaimer next to the permission infos !
Thx !!
ChuckPa
December 12, 2021, 6:31am
6
I’m in the process of updating all the FAQ.
This is the main FAQ question you’d use
Installation and Setup of Plex Media Server on Synology
This How-To is in multiple parts to make it easier to find whichever specific step you’re looking for.
If you’re new to Plex then reading this thread in sequence is probably the best approach.
This will show you how to install Plex on your Synology and then suggest a couple ways you can organize your media.
Please remember,
You’re always free to do it any way which makes sense to you.
We only ask you take the common pitfalls into cons…
It’s on my list to update and include DSM 7.
There’s so much to update
The full FAQ is here.
system
Closed
March 12, 2022, 6:31am
7
