Plex Media Server 1.31.3.6819 is now available to Plex Pass users in the Beta update channel.
NEW:
- (MacOS) This is the last release to support MacOS 10.11-10.12
- (Windows) This is the last release to support Windows 7-8.1
FIXES:
- (CreditsDetection) Improve temporary directory clean-up (#14169)
- (NativeSeriesScanner) Addressed an issue where certain filenames could falsely register as an episode range. (#14154)
- (Transcoder) Converting certain files could be unreliable when using Nvidia GPUs with certain driver versions (#14069)
Plex Media Server 1.31.3.6856 is now available to Plex Pass users in the Beta update channel.
NEW:
FIXES:
- (Scanner) Certain episode filenames could lead to excessive memory usage (#14215)
Plex Media Server 1.31.3.6868 is now available to Plex Pass users in the Beta update channel.
NEW:
FIXES:
- (Windows) 64-bit installer would not install on Windows ARM64.
Plex Media Server 1.31.3.6868 is now available to everyone.
Ridley
569
Plex Media Server 1.32.0.6865 is now available to Plex Pass users in the Beta update channel.
NEW:
- (Windows) The minimum supported Windows client operating system is now Windows 10 Version 1607
- (Windows) The minimum supported Windows server operating system is now Windows Server 2016
- (macOS) The minimum supported version is now macOS 10.13
FIXED:
- (QNAP) Make TMP folder visible in FileStation. (#14172)
- (Windows) Transcodes could be restricted to low-power efficiency cores on hybrid processor models (#14192)
Ridley
570
Plex Media Server 1.32.0.6918 is now available to Plex Pass users in the Beta update channel.
FIXED:
- (Transcoder) Subtitle fonts for some languages were missing on Linux and FreeBSD
- (Windows) Installing a TLS certificate could fail at random
Ridley
571
Plex Media Server 1.32.0.6918 is now available to everyone.
Ridley
572
Plex Media Server 1.32.0.6950 is now available to everyone.
FIXES:
- (Windows) Scanning libraries on certain network mounts could fail (#14259)
Plex Media Server 1.32.1.6954 is now available to Plex Pass users in the Beta update channel.
NEW:
- (Logging) Transient and per-startup local admin tokens are now fully redacted in logs by default (#13986)
FIXES:
- (Credits Detection) Detection could sometimes use the incorrect stream information (#14216)
- (Downloads) Transcoded downloads counted against per-user streams (#14139)
Ridley
574
Plex Media Server 1.32.0.6973 is now available to everyone.
FIXES:
- (HTTP) A newly-created TLS certificate could fail to be installed
Plex Media Server 1.32.1.6983 is now available to Plex Pass users in the Beta update channel.
FIXES:
Plex Media Server 1.32.1.6999 is now available to Plex Pass users in the Beta update channel.
NEW:
FIXES:
- (Plugins) Secure connection requests would fail to load on Windows machines (#14279)
- (TerraMaster) Improve hardware transcoding compatibility on TOS 5 platform
Ridley
577
Plex Media Server 1.32.1.6999 is now available to everyone.
Plex Media Server 1.32.2.7002 is now available to Plex Pass users in the Beta update channel.
NEW:
- (Library) Add additional episode deletion policy for âafter a monthâ (#14059)
- (Network) IPv6 addresses within the serverâs configured network prefix are now considered local for bandwidth allocation purposes (#14234)
- (Network) IPv6 network blocks are now supported in the LAN Networks preference (#14234)
- (Transcoder) Added HDR tone mapping support for Intel Arctic Sound-M and Meteor Lake GPUs (#14281)
- (Transcoder) Improved hardware transcode stability when using Intel GPUs on Linux (#14281)
- (Transcoder) Removed support for Intel hardware transcoding on FreeBSD (#14281)
- (Security) Support new, streamlined first-run claiming experience on Windows (#14270)
** see New Claiming Requirement for Windows for details.
FIXES:
- (Collections) Custom order for Collections were not saving (#13582)
- (Library) In certain specific cases, âEmpty Trashâ could remove items it shouldnât (#14141)
- (Music) Some TIDAL tracks in server play queue would be played in AAC and not FLAC.
- (Scanner) Certain episode filenames could appear to be episode ranges (#14230)
- (Scanner) Certain episode filenames could appear to be episode ranges (#14267)
- (DVR) Recordings fail with permission error (#14265)
Plex Media Server 1.32.2.7088 is now available to Plex Pass users in the Beta update channel.
NEW:
FIXES:
- (Windows) Certain Windows region settings could cause unexpected behaviour in some operations like scanning (#14304)
- (Windows) Server settings could take a very long time to load
Plex Media Server 1.32.2.7100 is now available to Plex Pass users in the Beta update channel.
NEW:
FIXES:
- (Transcoder) Some sessions could fall back to software when attempting to use an Nvidia GPU
Plex Media Server 1.32.2.7100 is now available to everyone.
Plex Media Server 1.32.3.7089 is now available to Plex Pass users in the Beta update channel.
NEW:
- (NAS) - Synology - Add support for DS223 family models (rtd1619 & rtd1619b processors)
FIXES:
- (Collections) Wording of collections display preference was confusing (#12176)
- (DVR) Finding USB device even if itâs plugged into a different USB port (#14288)
- (Photos) âRecently Added in Photosâ may not include any items in a sub folder (#12469)
- (PlayQueue) Playing an episode in a show that has a later aired unmatched episode could play the wrong episode (#13315)
Plex Media Server 1.32.3.7162 is now available to Plex Pass users in the Beta update channel.
NEW:
FIXES:
- Fixed release for NVIDIA Shield
Plex Media Server 1.32.3.7162 is now available to everyone.
