janoskk
December 8, 2022, 11:09am
544
Plex Media Server 1.30.0.6486 is now available to Plex Pass users in the Beta update channel.
NEW:
(PlexMatch) Add support for pattern matching (#13899 )
(Scheduled Tasks) Perform periodic metadata refreshes on TV shows too (#13920 )
(Transcoder) Support zero-copy hardware transcoding on macOS (#13904 )
FIXES:
(Artwork) Restrict client artwork screensaver to items user is allowed to access (#13916 )
(DVR) Commercial detection could fail on 32-bit Windows builds (#14002 )
(DVR) Plex Tuner Service might become unresponsive in certain complex scenarios (#12988 )
(Music) Some tracks may show lyrics being available when they are not (#13926 )
(QNAP) Renewed code signing certificate
(Scanner) Episodes of series with names beginning with a single digit could be mis-matched (#13921 )
(Windows) Added new code signing certificate for app binaries
(macOS) The server could fail platform security checks on older macOS versions (#13959 )
janoskk
December 13, 2022, 8:10am
545
Plex Media Server 1.30.0.6486 is now available to everyone
Plex Media Server 1.30.1.6483 is now available to Plex Pass users in the Beta update channel.
NEW:
(Extras) Improved support for matching TV series extras with common community filename formats (#4774 )
(Preferences) Added an advanced preference for DB cache size.
(Settings) Add configurable played percentage threshold advanced library preference (#13860 )
(Transcoder) Added support for AV1 video decoding (#13941 )
(Transcoder) The minimum supported Nvidia driver version for hardware transcoding has been increased to 455.28 on Linux and 456.71 on Windows (#13941 )
FIXES:
(Bandwidth) Server could become unresponsive under certain timing conditions (#13951 )
(Database) Server might quit unexpectedly after SQLite3 syntax errors (#13942 )
(Transcoder) Transcodes could fail when converting bitmap subtitles to the DVD format (#13967 )
Plex Media Server 1.30.1.6497 is now available to Plex Pass users in the Beta update channel.
NEW:
(NAS) Add Support for TerraMaster TOS 5 platforms.
FIXES:
(PlexMatch) Pattern matching could behave incorrectly for certain filenames (#14030 )
(macOS) Some endpoints could return errors on macOS versions older than 10.15 (#13946 )
Plex Media Server 1.30.1.6550 is now available to Plex Pass users in the Beta update channel.
NEW:
FIXES:
(Transcoder) Decoding certain TrueHD audio streams could fail (#14023 )
Plex Media Server 1.30.1.6562 is now available to Plex Pass users in the Beta update channel.
NEW:
FIXES:
(Analysis) Loudness analysis could crash if item was removed
Plex Media Server 1.30.1.6562 is now available to everyone.
Ridley
January 10, 2023, 9:10pm
551
Plex Media Server 1.30.2.6563 is now available to Plex Pass users in the Beta update channel.
NEW:
(Scanner) .plexmatch files now support a new match type called âSEEâ, which allows handling of files where e.g. â302â means episode 2 of season 3 (#13985 )
(Scanner) .plexmatch pattern matching tokens now support setting a maximum length on matches; see the âMatch Hinting for TV Seriesâ support article for details (#13985 )
(Scanner) Files named using the uncommon âSEEâ format are no longer matched by default; please use the .plexmatch feature to handle these files (#13985 )
(Scanner) Files with names containing a 3- or 4-digit standalone episode number are now matched correctly by default (#13985 )
FIXES:
(DLNA) Corrected DLNA server not starting on NVIDIA Shield (#13340 )
(DVR) DVR schedule is now corrected when the guide updates. (#13217 /#12821 )
(DVR) Preview thumbs not being created for DVR recordings (#13943 )
(Library) TV theme music could incorrectly remain on an item after fixing a match (#13933 )
(Library) Unprocessed Add to Library items can crash the server on startup if the original library section no longer exists (#14022 )
(MacOS) Incorrect download progress percentage for updates is passed to the web client (#13992 )
(Metadata) Episodes would not store the year field (#13974 )
(Music) Improve reliability of maintaining original add date when upgrading albums.
(Music) When replacing exisiting files with new versions, loudness analysis would not trigger on demand (#13897 )
(Network) The server could fail to publish any LAN addresses if a preferred network interface was selected, but was not available (#14001 )
(Pivots) Categories pivot loading time might be slow for larger libraries (#13912 )
(Transcoder) Download transcodes consumed slot even after transcode completes (#13987 )
(Versions) Optimized versions of an edition would overwrite any existing version using the same profile (#13746 )
Ridley
January 25, 2023, 4:48am
552
Plex Media Server 1.30.2.6563 is now available to everyone.
Plex Media Server 1.31.0.6654 is now available to Plex Pass users in the Beta update channel.
NEW:
(Linux) Automatic library updates are now triggered by filesystem permissions and ownership changes (#14045 )
FIXES:
(DVR) Some audio or subtitle streams could fail to be captured on channels with multiple audio or subtitle services (#13908 ) (#13877 )
(IntroDetection) Detection may timeout on very slow systems causing items to retry indefinitely (#14027 )
(Transcoder) Transcoding from AV1 could take a very long time to start when a GPU that did not support it was present (#14043 )
Plex Media Server 1.31.0.6654 is now available to everyone
NEW:
Detect end credits markers for movies and episodes (Plex Pass required)
Allow using end credits markers to determine fully watched state for movies and episodes (Plex Pass required)
FIXES:
Plex Media Server 1.31.1.6716 is now available to Plex Pass users in the Beta update channel.
NEW:
(Scanner) Adds support for the Extend multi-episode format i.e. S01E01-02 (#14064 )
(Subtitles) Attempt to automatically detect improperly-tagged forced streams based on their titles (#14096 )
(TV) Provide clients with the number of non-Specials seasons for display when browsing (#14036 )
(Web) Updated to 4.100.1
Add Ukrainian translations.
Updated translations.
FIXES:
(Clustering) Photos timeline - duplicated items or incorrect dates (#14081 )
(Credits Detection) The detection could timeout and fail on low powered devices.
(CreditsDetection) Fix assignment of final marker attribute (#14109 )
(Intros) Detection wouldnât proceed if background transcodes were paused (#14056 )
(Music) When shuffling smart playlists with limits, the track selection could be incorrect.
(Transcoder) Hardware decoding using Nvidia GPUs could fail with certain driver versions (#14069 ) (#14070 )
Plex Media Server 1.31.1.6733 is now available to Plex Pass users in the Beta update channel.
NEW:
FIXES:
(Credits Detection) Detection could fail with certain video codecs (#14150 )
(Credits Detection) Limit thread concurrency for first stage of detection (#14150 )
Ridley
February 27, 2023, 7:09pm
557
Plex Media Server 1.31.1.6733 is now available to everyone.
janoskk
February 28, 2023, 9:10am
558
Plex Media Server 1.31.2.6739 is now available to Plex Pass users in the Beta update channel.
NEW:
(TV) Add series- and season-level preferences controlling audio and subtitle stream selection (#8036 )
FIXES:
(Playlist) > Smart playlists could fail when set to show/season/artist/album types when requested by someone other than server admin (#13427 )
(Push) The server could exit unexpectedly if a database error occurred within certain notification-handling code (#14112 )
(Scanner) TV episodes with certain naming formats involving underscores could fail to be scanned in (#14111 )
Plex Media Server 1.31.2.6757 is now available to Plex Pass users in the Beta update channel.
NEW:
FIXES:
Request to system/agents could fail.
Plex Media Server 1.31.1.6782 is now available to everyone.
This is a hotfix release.
NEW:
FIXES:
(First Run) Library creation could fail during set up (#14161 )
Plex Media Server 1.31.2.6783 is now available to Plex Pass users in the Beta update channel.
NEW:
FIXES:
Plex Media Server 1.31.2.6810 is now available to Plex Pass users in the Beta update channel.
NEW:
FIXES:
(CreditsDetection) Scanner might quit unexpectedly in some cases (#14169 )
(First Run) Library creation could fail during set up (#14161 )*
Plex Media Server 1.31.2.6810 is now available to everyone.
