Plex Media Server
Plex Media Server 1.32.4.7164 is now available to Plex Pass users in the Beta update channel.
NEW:
  • (Web) Updated to 4.108.0
FIXES:
  • (Analysis) Processing an invalid audio file could result in the scanner stalling while producing very large amounts of log data (#14335)
  • (Bandwidth) Very low WAN bandwidth streams could get starved (#14319)
  • (Collections) Refreshing item counts for smart collections could block other operations during startup (#14327)
  • (Library) Advanced Filter for Editions returning unexpected results (#14106)
  • (Library) Items with EPG data could sometimes lose certain metadata fields (#14303)
  • (Transcoder) Hardware transcoding could fail to be used on older Intel GPUs on Linux (#14338)
Plex Media Server 1.32.3.7192 is now available to everyone.
This release fixes a security issue in Plex Media Server’s auto-update service on Windows. The issue allowed a local unprivileged user to cause denial of service on the system. This cannot be exploited by an attacker without existing user access to the machine, and we’re not aware of any way to use it to escalate to administrator privileges or gain code execution. Nevertheless, we recommend that all users running Plex Media Server on Windows update to this new version as soon as possible, particularly those who run it on shared systems.
NEW:
  • (NAS) - Synology - Add support for DS223 family models (rtd1619 & rtd1619b processors)
FIXES:
  • (Collections) Wording of collections display preference was confusing (#12176)
  • (DVR) Finding USB device even if it’s plugged into a different USB port (#14288)
  • (Photos) “Recently Added in Photos” may not include any items in a sub folder (#12469)
  • (PlayQueue) Playing an episode in a show that has a later aired unmatched episode could play the wrong episode (#13315)
  • Fixed release for NVIDIA Shield
  • (Windows) Certain Windows region settings could cause unexpected behaviour in some operations like scanning (#14304)
  • (Windows) Fixed potential file delete/overwrite in updater by an unprivileged user (#14370)
Plex Media Server 1.32.4.7195 is now available to Plex Pass users in the Beta update channel.
NEW:
FIXES:
Plex Media Server 1.32.4.7195 is now available to everyone.
Plex Media Server 1.32.5.7210 is now available to Plex Pass users in the Beta update channel.
NEW:
  • (Music) Add “Deep Cuts” station.
  • (Transcoder) Hardware transcoding is now supported for SDR media on AMD GPUs on Linux (#14332)
  • (Transcoder) Hardware transcoding is now supported when running Plex Media Server on headless Windows systems (#14332)
  • (Transcoder) The GPU used for transcoding can now be selected in server preferences (#14332)
FIXES:
  • (Filters) Date-based filters could be off by a day in some time zones (#14342)
  • (Library) Poster previews in metadata edit screen could become blank if the selected poster failed to download (#14360)
  • (Music) In some cases, less popular tracks were picked in stations.
  • (Photos) The server could exit unexpectedly when reading TIFF or RAW image files (#10924)
  • (Scanner) Movies and TV shows would fail to match when invoked from the scanner CLI (#14386)
  • (Transcoder) Hardware transcoding could fail on Intel Apollo Lake GPUs (#14359)
  • (Packaging) RPM packages are now signed using SHA-512 instead of SHA-1 (#14369).
Plex Media Server 1.32.5.7318 is now available to Plex Pass users in the Beta update channel.
NEW:
FIXES:
  • (EPG) Filters were constructed using timestamps in local server time instead of UTC (#14431)
  • (Packaging) RPM packages are now signed using SHA-512 instead of SHA-1 (#14369).- (Photos) The server could exit unexpectedly when reading TIFF or RAW image files (#10924)
Plex Media Server 1.32.5.7328 is now available to Plex Pass users in the Beta update channel.
NEW:
FIXES:
    - (Library) New TV show theme songs would not get downloaded (#14451)
Plex Media Server 1.32.5.7328 is now available to everyone
Plex Media Server 1.32.5.7349 is now available to everyone.
NEW:
FIXES:
  • (Windows) Fixed potential privileged execution in updater by an unprivileged user (#14406)
Plex Media Server 1.32.6.7371 is now available to Plex Pass users in the Beta update channel.
FIXES:
  • (Agents) Some attributes were missing from legacy agent api responses (#14436)
  • (Analysis) MP4 Atom Parsing could fill logs (#14418)
  • (Automatic Scanning) Symbolic links with missing targets could cause changes to later entries in a directory not to be detected (#14398)
  • (DVR) Could not record a show if a show with the same name (such as a remake) and episode number already existed in the target library (#13444)
  • (DVR) Devices could fail to be recognized when IP addresses change (#13529)
  • (DVR) Multi-lineup DVRs could be created as single-lineups (#14395)
  • (DVR) Tuning in channels could fail for channel names containing special characters (#14391)
  • (Debian) Remove GPG lower version limit
  • (Music) Scanning music could be pathologically slow in some cases (#14389)
  • (Playlist) Adding a Clip to a playlist would unexpectedly convert it to a photo playlist (#14381)
  • (Transcoder) An incorrect fallback font could be used when burning subtitles in some cases (#14357)
  • (Transcoder) Certain newer AMD GPU models couldn’t be used for hardware transcoding on Linux (#14416)
Plex Media Server 1.32.5.7431 is now available for all Nvidia Shield users.
FIXES:
  • (Nvidia Shield) The setup process would fail on first run.
Note: This version has been temporarily rolled back. We will update this as soon as it’s brought back. For more information, see this thread.
Plex Media Server 1.32.6.7468 is now available to Plex Pass users in the Beta update channel.
FIXES:
  • (Filters) Filtering on dates before/after 1970-01-01 would result in an error (#14511)
  • (Mac) Transcoder crashes would cause PMS to exit (#14414)
  • (Music) Searches for lyrics could be run unnecessarily (#14513)
  • (Thumbnails) Certain JPEG images caused PMS to exhibit unexpected behavior when generating thumbnails (#14407)
  • (Transcoder) Unexpected behavior when subtitles ended before the end of video (#14426)
  • FreeBSD builds would crash on start-up (#14499)
Note: This version has been temporarily rolled back. We will update this as soon as it’s brought back. For more information, see this thread .
~Plex Media Server 1.32.6.7468 is now available to everyone~
Plex Media Server 1.32.7.7484 is now available to Plex Pass users in the Beta update channel.
NEW:
  • (TerraMaster) Improve multi-volume support when adding folders to libraries.
  • (Transcoder) Enable hardware transcoding by default where available (#14282)
FIXES:
  • (Hubs) User could order a hub before Continue Watching hub (#14236)
  • (Library) In some cases, media item presence and accessibility could fail to be reported (#14307)
  • (Photos) Autotag data was not visible even if photos had pre-existing autotags (#14493)
  • (Photos) Places filter was not visible even if photos had pre-existing place data (#14519)
  • (Preferences) Adjust library section preference text for intro and credits detection (#14152)
  • (Scanner) Episodes with absolute numbering of 264 and 265 could get ignored (#14084)
  • (Security) Certain requests could trigger unwanted notifications (#14524)
  • (Transcoding) Some HW encoded video would not play on Android (#14384)
Plex Media Server 1.32.5.7516 is now available in both the Public and Beta Update Channels
There are no changes from 1.32.5.7349, however a new deployment was necessary to roll back 1.32.6 from repositories such as Debian and Docker
Plex Media Server 1.32.6.7521 is now available to Plex Pass users in the Beta update channel.
FIXES:
  • (Transcoding) Hardware transcoding failed on linux machines (#14553)
Plex Media Server 1.32.6.7557 is now available to Plex Pass users in the Beta update channel.
FIXES:
  • (Library) Some of the hubs on preplay screens may not load (#14562)
Plex Media Server 1.32.6.7557 is now available to everyone.
Plex Media Server 1.32.7.7571 is now available to Plex Pass users in the Beta update channel.
NEW:
FIXES:
  • (Metadata) Items could lose metadata if a refresh request failed due to a network failure (#14551)
Plex Media Server 1.32.7.7616 is now available to Plex Pass users in the Beta update channel.
NEW:
FIXES:
  • (Security) Curl version contained a vulnerability that could be exploited if user set a SOCKS proxy in env.
