@Evoc said:
Great job so far, just a little curious what’s different with Tautulli than PlexPY? Or is this the latest version that will receive new updates?
I’ m sorry - but did you even try to look this up yourself before asking?
Awesome! Haven been waiting for the official release. Quickly scanned through the Install and FAQ links and didn’t see a way to upgrade from PlexPy directly. I thought I remember you were stating that we would be able to upgrade from within the app to this version, is this still the case?
I am already running 3 x PlexPy for 3 different Plex server’s would the new Tautulli support multiple Plex servers?
That would be a great feature, SHIELD is a low cost Plex server so more people are having more than one Plex server.
Love PlexPy and I am looking forward to try out Tautulli
@sibberio said:
on version 2.0.6 you introduced the Plex Cloud monitoring. How can I configure it?
There’s no documentation about that
Go to https://plex.tv/users/cpms, look under PMS Links and copy your Plex Cloud Instance Link.
Then go to Tautulli/Settings/Plex Media Server and paste the link to the Hostname (remove the https:// part), choose Port 80, check Remote Server and Use SSL.
I have used PlexPy and love it. I saw that Tautulli was finally out so I followed all of the installation instructions and I believe I have it running (the settings page shows all of the correct Tautulli folders and such and the logs are writing there), but…
**The main page (home screen) still shows PlexPy and not Tautulli like the screen shots show. What am I doing wrong?
**I saved the old PlexPy directory, is it possible to get the history from it and have it show for Tautulli so I have my year+ of historical stats?
@WannabeMKII said:
I’m currently running PlexPy as a Docker image, but I’m sure I read somewhere recently that it’s possible to change some settings to move to Tautulli?
Is this possible?
Anyone able to assist with this or point me in the right direction?
Thanks but now there’s a cool drop down menu to select it
well I’ve 2 separate docker. One with plexpy and one with Tautulli.
I suggest you to install this container hub.docker.com/r/tautulli/tautulli/ and migrate the data from the old one to the new one
I’ve added a second docker like mentioned, but it still appears branded as PlexPy and the version numbers are the same, 1.4.25?
I’ve used UnRaid for few days and I can’t help you.
I’ve seen online that you can set Environment Variables. In this case the Variable name is “ADVANCED_GIT_BRANCH” and the value should be “beta”.
I think you have to enable the advanced mode
